Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop doesn't display when booting up
I have a amilo pro laptop and today when I boot it up nothing displays on the screen.
I attached the laptop to a monitor and the message is: Autodetect and Powersave mode.
How can I get the laptop to display on the laptop monitor.
Thanks
    Sergeant:
  • 366 Answers
Be sure to be on AC and have battery recharging.
Then find on your keyboard the key used to circle through active display, it's usually having a screen icon on same color than FN (function) key.
Use both to change your active display: Main > external > both pause between changes, system needs time for reset.
Posted on Jan 24, 2009
Take out the battery and boot laptop purely on power without power.
If its successfull then put the battery in and it will be fine.. Later on get the battery replaced
I have an Amilo Pro V2035 and when switching on it only display 'BootMGR compressed.' I'v tried to press Ctrl+Alt+Del but nothing has changed. Pliz help me how I can restart the Laptop.
press F12 for boot manager before the screen displays bootmgr compressed.. Sounds like your hard drive may have developed a problem. When you press f12 you should get some startup options.insert your OS CD
go to DOS window and type in your OS drive (usualy C:\)
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
Oct 18, 2013 | Computers & Internet
The display on my Amilo Pro V2030 is black after it fell on the floor. Does this necessarily mean that the display is dead and needs to be replaced or external monitor used? Could the problem be fixed in...
May be a loose connection, at best, at worst, HDD damaged, etc., etc., etc.. Does it boot? Fan spins? LED's Blink? Sound? Anything? If you connect a External Monitor does it work? There are cable at the bottom and rear of the monitor that can come loose.
May 04, 2013 | Fujitsu Siemens Amilo Pro V2030 Laptop...
My FUJITSU SIEMENS AMILO PA 1538 screen comes black ? HELP
Try connecting the laptop to an external monitor and see if all is working Ok with that, if it is, then you may need to get the laptop display serviced - if it does the same on the external display, then try booting the laptop from a CD or DVD such as an OS install CD (Windows or Linux) or a boot utility CD such as Hiren's Boot CD - this will allow you to test whether the problem lays with your installed operating system or with the hardware. . . .
Note: do not go any further than the initial displays if using an OS install CD unless you are using a Linux Live boot CD which will not destroy your installed operating system. . . .See http://www.hirensbootcd.org/ to download a copy of Hiren's Boot CD to burn to a CD. . . .See http://www.ubuntu.com/download/ubuntu/download to download a copy of a Ubuntu (Linux) Live CD.
Dec 17, 2011 | Computers & Internet
Sir i am getting problem in booting from usb dvd ram because my installed combo drive is not working ,so how can i boot from usb dvd ram and laptop cmp is "amilo pro fujtshi siemens"
You have to go in BIOS and choose in menu to boot from USB device (USB HDD, USB FLOPPY, USB CD-ROM and other in menu). To go in BIOS you press DEL or F2 or another button who writes on the first screen after you turn on the laptop. Good luck.
Jan 31, 2011 | Fujitsu Siemens Amilo Pro V2040 Laptop...
When turning on your computer, there should be a screen display either in your brand logo that promts to press a key to enter setup,bios etc. or boot priority. If it takes you into the BOIS menu, go to the boot tab, and change your boot priority to usb as first boot priority. Save and exit, you should be good to go. Should boot from the usb dvd.
Jan 31, 2011 | Computers & Internet
Fujits amilo pro v2030 will not boot up
Are you getting the BIOS info on the screen?
If you can access the BIOS check all the setting.
Hard Drive installed, Boot Sequence and so-on.
If you get NOTHING on the screen but can hear it "running", try plugging in a Monitor, you may have to find the monitor key, usually = hold "Fn" + Press "F5" to switch screen to monitor to both.
Oct 08, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Screen going blank on fujitsu siemens amilo L1300
hi
change place og your magnetic device nearly to display if there.
reset your monitor.
degauss it.
also check your cpu display option with other display if u have.
Mar 25, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo Pro V Fuitsu/Siemens Problem
It may be the lcd or windows, press F8 on start up and see if you get a safe mode screen, if so highlight start windows with last known good configuration and allow a re-boot. If it is the lcd you can shine a torch at the screen to see if you can see the startup screen, if so the back light may be damaged and in need of a professional repairer
Jan 21, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
283 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
