Question about Porter Cable C2002 Wk Oil Free Umc Pancake Compressor w/13 Piece Accessory Kit
Pancake compress just stopped.
Is there a fuse located on the unit?
  • 2,176 Answers
No there is not from I can see from the breakdown and manual. They suggest that you check your circuit breakers in the electrical panel, extension cord length or loose wire in the box, If nothing they recommend that you take the unit in for a trained service tech to look at it. If you want or need a manual for this go to Dewaltservicenet.com and in the middle of the page at bottom type in the model number and you can look at both. Sorry but this is all I can find for you.
Posted on Jan 24, 2009
How to change a regulator on a bostich pancake compressor
Usually they are just threaded into the unit, Empty the air, then remove it,
Oct 11, 2014 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Unit has developed a continuous leak
need to replace pressure switch as the leak is a worn needle valve assembly. it usually unloads from there when the machine stops
Sep 06, 2012 | Clarke Power Products Inc AC2001 2HP 4...
My air compressor won't compress more than 40 lbs what can I do?
Your compressor is worn or dirty or both. Disassemble the head and inspect it. Look for dirt in the reed valves ... look for excess sloppyness in the piston (worn rings)
You may be able to repair this, expect to pay $50.00 for a kit (you dont ID the unit so I cannot make a recommendation) ... It may be cheaper to replace the unit rather than have it repaired professionally.
May 31, 2010 | Air Tools & Compressors
Blown capacitor
Radio Shack ... Jonestone Supply ... FixYa.com advertiser ... any place that services electric motors.
Thanks for your interest in FixYa.com
May 26, 2010 | Clarke Power Products Inc AC2001 2HP 4...
PORTERCABLE COMPRESSOR
hi there,
there are considering factors to be check.the belt tension of the motor should be fitted between motor and compressor to avoid slip tension of the belt.adjust motor alignment.if still not compressing air
or lost compression replace piston ring.have a nice day dont forget to fix my rate/thank you
May 07, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
I need a drain plug for a Clarke Air pancake two horse compressor. Model AC2001 Serial # 1005188 Where can I locate one? Dan
Master tool repair is a good web site to get things like that, they sell a lot of generic parts like that
Dec 29, 2009 | Clarke Power Products Inc AC2001 2HP 4...
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
Capacitor bad need one
These look reasonable, http://www.famousdiscountwarehouse.com/stca43to336m.html Eric
Sep 03, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Will not pressure up even though it runs and runs and runs
Check for leaks of course... THEN check the check valve AND the Compression Relief valve which is OFTEN cintained in teh pressure switch. This valve bleeds the compression left in the head so the thing can restart without a pressure load. This is a small pintle that closes when the pressure switch starts the compressor. The check valve is the other thing and it is often a part of either the head or the pressure line to the tank at the tank.
Aug 17, 2009 | Porter Cable C2002 Oil Free Umc Pancake...
Porter Cable C2002 Wk Oil Free Umc Pancake Compressor w/13 Piece Accessory Kit Logo
115 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
