Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Trinitron KV-36FS13 I have a 36" Sony Trinitron television set that suddenly will not power on. There were no symptoms -- the TV was working perfectly well last night, turned it off for the evening and this morning it would not power up. I tried tp plug the set into a different outlet but no response. There are some peripherals connected to the TV, i.e., a DVD player, cable Box and VCR, buy they all power up just fine. Could it be a power supply on the TV? The set is over three years old but with no diminishing signs. Any ideas?
  • 1 more comment
  • John Protzel Jul 10, 2007
    Wher would the fuses be located?
  • Anonymous Jun 22, 2008
    I have the same problem. The set was working fine, then suddenly stopped working. I turned it off yesterday, went to turn it on today and nothing. All of the other components (DVD, Receiver, etc.) are powered on and working fine.
  • tonimmorris Sep 18, 2008
    I have this issue. WHERE IS THE FUSE??????
    Thanks!!
  • 432 Answers
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Posted on Jul 10, 2007
SOURCE:
Sony TV not turning on
Chances are the Power Supply failed because the Horizontal circuit failed. It would not be out of line if the repair cost ran 250.00 plus.
It is probably not worth fixing due to the age of the set.
Hope this helps,
Skyassoc
Jul 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Need some body to help me, could you send me copy off schematic drawing Sony Trinitron Colour TV model : KV-PG21P40. I nedd to check the defective power oscillation.
These are not available for free anywhere that I am aware of. That being said, what is the problem you are having with the set? Perhaps we can assist with some diagnostic suggestions or possible solutions based upon the symptoms you describe.
Dan
Mar 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Feb 20, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
MY SONY
how many blinks do you see or count on the red led
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
No picture no sound KV-32FS120
dear talas, i do hope that your sony have frame problem try remove the vertical I.C and replace with another
thanks
Dec 20, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-21X4U
did you see anything on screen at all event the sound.
Dec 01, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
