Question about Plumbing
Kitchen faucet makes loud thumping noise when turned on.
  • 68 Answers
SOURCE: price pfister kitchen one handle faucet makes loud
maby look in to getting a prv for your house sounds like you have high water pressure
Posted on Mar 15, 2009
  • 2692 Answers
SOURCE: hot water faucet makes loud noise when first turned on
Fix Ya, then?
Posted on Mar 19, 2009
  • 23 Answers
SOURCE: Kitchen sink,,moen one handle,,makes a lot of
the noise is probably the pipes in the walls banging, a shock arestor can be installed. as for the sprayer some faucets just work like that
Posted on Oct 31, 2009
  • 5 Answers
SOURCE: The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Posted on Feb 10, 2010
djchillsnyc
  • 151 Answers
SOURCE: sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Posted on Jun 07, 2010
I have a glaicer bay kitchen faucet and when the water is turned on there is thumping. When I take the sprayer off the thumping stops.... is therea probelm with the sprayer?
to reduce the 'thumping' noise, open the supply valves more. If they are already at maximum, you may have a restriction further up the supply lines. Thumping is typically caused by unbalanced flow around the seat and washer, usually caused by restrictions.
Mar 03, 2014 | Glacier Bay Kitchen Faucets. Lyndhurst...
There is a "thumping" noise
Sounds like your water pressure may be to high for the faucet, an inline regulator might be all you need. You didn't mention if it thumped once or repeatedly, if its the latter, you may need to install an expansion tank. Next time you turn it on, try it to the left (hot), and to the right (cold) to see if it only makes the sound on the hot side, if so an expansion tank may needed. Good Luck
Jan 14, 2011 | Price Pfister Plumbing
I just bought a new Delta kitchen faucet, it is a two handle, sprayer model. It makes a thumping noise when I first turn the water on and when I use the sprayer . I've been told to replace the diverter....
The thump comes from one of several areas. Air pressure in the hand sprayer is one.
But I suspect that you need to check your shut off valves. Old style (non ball) valves fail during this event. There is a little washer that deteriorates, over time....
Then you need to install a faucet, you shut the valves and the little washers either break or come loose. When they break, little pieces go up and clog the faucet.
The other failure is they partially block flow afer coming loose, and cause a thump, like what you describe. To fix, shut off main water in the house and DRAIN what you can. Best to replace with whole new valve, but next best is to replace the guts, unscrew and take to hardware store and get new stem and guts. Inspect the seat, often they get damaged and pitted. Nor necessarily an issue on this install, as the valve in normally open...
Oct 17, 2010 | Delta Home
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Sink sprayer hose makes noise
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
Plumbing Logo
113 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
