Question about Nikon Microscope Alphaphot-2 Ys2-t 4 Objectives Cfwe 10xa/18 Eyepiece E100 1.25
Pinion gear for raising & lowering condenser tray is broken need part #
Condenser tray falls free and can be raised by hand
    Problem Solver:
In the Optiphot there are two small grub screws under the left hand side of the condenser column. Once loosened the metal housing of the pinion can by pulled or pushed out and the new one inserted. You may need a small mirror to see the screws due to their hidden position. You can then replace the pinion in which the black nylon gear will have broken
Posted on Dec 10, 2014
How do you replace the rack and opinion on a 92 cutlass ceira
Here you are - power rack & pinion.
Except 2.2L and 1993-96 3.1L Engines
See Figure 1
  1. Raise the intermediate shaft seal and remove intermediate shaft-to-stub shaft pinch bolt.
  2. Remove the air cleaner and disconnect the pressure hoses from the steering gear.
  3. Raise and support the vehicle on jackstands, then remove both front wheel and tire assemblies.
  4. Remove the cotter pins and nuts from both tie rod ends. Using tool J-6627 or BT-7101, press the tie rod ends from the steering knuckle.
  5. If equipped with an Air Management pipe, remove the bracket bolt from the crossmember.
  6. Remove the 2 rear cradle mounting bolts and lower the rear of the cradle about 4-5 in. (102-127mm).
WARNING
If the rear of the cradle is lowered too far, the engine components nearest the cowl may be damaged.
  1. If equipped, remove the rack and pinion heat shield.
Fig. Fig. 1: Power rack and pinion assembly
  1. Remove the rack and pinion mounting bolts, then the gear assembly through the left wheel opening.
To install:
  1. Install the gear assembly through the left wheel opening and install the mounting bolts.
  2. Install the heat shield.
  3. Raise the rear of the cradle and install the mounting bolts.
  4. Install the bracket bolt to the crossmember under the air management pipe.
  5. Install the tie rod ends to the steering knuckles, install the retaining nuts and insert new cotter pins.
  6. Install the front wheels and lower the vehicle.
  7. Install the high pressure hoses to the steering gear and install the air cleaner.
  8. Install the intermediate shaft seal and the intermediate shaft-to-stub shaft pinch bolt.
2.2L Engine
  1. Disconnect the negative battery cable.
  2. Install an engine support fixture J-28467-A, or the equivalent.
  3. Raise and safely support the vehicle.
  4. Remove the tire and wheel assembly.
  5. Remove the intermediate shaft lower pinch bolt.
  6. Disconnect the intermediate shaft from stub shaft.
CAUTION
Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury.
  1. Remove the exhaust pipe hanger bracket near rear of frame including the brake line retainer and rubber exhaust pipe hangers.
  2. Remove the engine and transaxle mount nuts at the subframe.
  3. Support the rear of the subframe with jack stands.
  4. Remove the rear subframe bolts and discard.
  5. Lower the subframe for access to rack and pinion.
Do not lower the rear of the cradle too far, as damage to engine components nearest the cowl may result.
  1. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  2. Disconnect the power steering lines from the steering gear.
  3. Remove the rack and pinion mounting bolts and nuts.
  4. Remove the rack and pinion through left wheel opening.
To Install:
  1. Install the rack and pinion through left wheel opening.
  2. Install the rack and pinion mounting bolts and nuts and tighten to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm) on the pressure line.
  4. Install the power steering line clip to steering gear.
  5. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  6. Raise the subframe into position and install new frame mounting bolts. Tighten the bolts to 103 ft. lbs. (140 Nm).
  7. Remove the jack.
  8. Install the engine mount and transaxle mount nuts and tighten to 39 ft. lbs. (53 Nm).
  9. Install the exhaust pipe hanger bracket near the rear of frame including brake line retainer and rubber exhaust pipe hanger.
  10. Connect the intermediate shaft to the stub shaft and tighten the pinch bolt to 29 ft. lbs. (40 Nm).
  11. Install the tire and wheel assembly.
  12. Lower the vehicle.
  13. Remove the support fixture.
  14. Connect the negative battery cable.
  15. Refill the power steering reservoir and bleed the system.
  16. Check the front end alignment and adjust as necessary.
3.1L Engine (VIN M)
  2. Remove engine torque strut from engine.
  3. Install an engine support fixture J-28467-A, or the equivalent.
  4. Raise and safely support the vehicle.
  5. Remove the tire and wheel assembly.
  6. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  7. Remove the center engine and rear transaxle mounts from the frame.
  8. Remove the intermediate shaft lower pinch bolt.
  9. Disconnect the intermediate shaft from stub shaft.
CAUTION
  1. Remove the brace bolts and brace, including brake line brace.
  2. Support the rear of the subframe with jack stands.
  3. Remove the rear subframe bolts and discard.
  4. Lower the subframe for access to rack and pinion.
  5. Remove the steering gear heat shield.
  6. Remove the clip holding lines at rack assembly.
  7. Disconnect the power steering lines and O-rings.
  8. Remove the rack and pinion mounting bolts and nuts.
  9. Remove the rack and pinion unit through the left wheel well.
To Install:
  2. Install the rack and pinion mounting bolts and nuts and tighten the mounting bolts to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm). on the pressure line.
  5. Install the steering gear heat shield.
  7. Remove the jack.
  9. Install the brace and bolts including brake line brace.
  11. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  12. Install the tire and wheel assembly.
  13. Lower the vehicle.
  14. Remove the support fixture.
  15. Connect the negative battery cable.
  16. Refill the power steering reservoir and bleed the system.
  17. Check the front end alignment and adjust as necessary.
Nov 01, 2015 | Cars & Trucks
How to replace rack an pinion cutlass ciera 1992
You aren't saying what engine is in it, or whether it is manual or power steering. Here is the R/R procedure for power steering rack for all engine sizes.
See Figure 1
WARNING
To install:
2.2L Engine
CAUTION
To Install:
  7. Remove the jack.
3.1L Engine (VIN M)
CAUTION
To Install:
  7. Remove the jack.
C-2257 error code
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot. This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
Apr 05, 2012 | Office Equipment & Supplies
I have a 3 1/2 ton floor jack it is a craftman it will lift, but whene i put weight to it it will not lift anything where do you put the oil in to it. thanks gerald
Hi, Gerald -
You either need to top up the oil, or change the oil. Both of these are easy to do.
You'll need some high-grade jack oil, an Allen wrench, a rag or two, and a funnel.
1.) Relieve the pressure and lower the jack arm all the way down.
2.) Remove the tool tray from between the two rear wheels.
3.) Wipe the oil fill plug clean. (You don't want any gunk or debris falling inside.)
4.) Remove the plug with the Allen wrench.
Look inside. If the oil level is at or below the inner cylinder wall, you'll need to add oil. Don't go more than 3/16"-1/4" above the inner cylinder wall.
With the pressure still off, gently raise & lower the arm two or three times. Check and adjust your oil level again. Then screw the plug back in & tighten it with your Allen wrench.
Everything OK? Great. If not, repeat 1 through 4, then lay the jack on its side & drain ALL the oil out (into a container). When it's empty, set it upright & fill it. Again, raise & lower the arm several times.
Replace the plug, tighten it, then test. Raise the jack all the way up, then lower it all the way down, without any load on it. Repeat this two more times. (This helps to dissipate the air bubbles in the oil.) It should now be ready to use.
Mar 02, 2011 | Plumbing
My rack and pion is leaking , how do i replace
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section. NOTE: The wheels of the vehicle must be straight ahead and the steering column in the LOCK position before disconnecting the steering column or intermediate shaft from the steering gear. Failure to do so will cause the SIR coil assembly (clock spring) to become uncentered, which may cause damage to the assembly.
  2. Lock the steering column by installing the J42640 into the underside of the steering column.
  3. Raise and support the vehicle.
  4. Remove the tires and wheels.
  5. Remove the power steering gear heat shield.
  6. Remove or disconnect the following: CAUTION
    Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control, which could result in personal injury.
    • Intermediate shaft lower pinch bolt and coupling from gear
    • Pressure and return pipes from the gear
    • Electrical connector, if equipped
      Stabilizer shaft links at lower control arms
    • Remove the left stabilizer shaft insulator.
    • Rotate the stabilizer shaft to access steering gear bolts.
    • The outer tie rod retaining nuts.
    • Using J24319-B separate the outer tie rods from the steering knuckles.
    • Rack and pinion attaching bolts
    • Rack and pinion assembly through the left wheel opening.
  7. Transfer the outer tie rods if replacing the power steering gear.
To Install:
  1. Install or connect the following:
    • Rack and pinion assembly through the left wheel opening and tighten the bolts to 70 ft. lbs. (95 Nm)
      Pressure and return lines to the steering gear and tighten the fittings to 22 ft. lbs. (30 Nm)
    • Heat shield and bolts. Tighten the bolts to 7 ft. Lbs. (10 N)
    • Install the left stabilizer shaft insulator.
  2. Install stabilizer shaft Links to lower control arms
  3. Intermediate shaft to the steering gear and tighten the pinch bolt to 35 ft. lbs. (47 Nm)
  4. Install the outer tie rods to the steering knuckles.
  5. Install the outer tie rods retaining nuts. torque the nuts to 22ft.lbs(30 Nm) plus an additional 180 degrees.
  6. Install the tires and wheels.
  7. Lower the vehicle.
  8. Remove the steering column anti rotation pin from the steering column.
  9. Fill and bleed the power steering system.
  10. Adjust the front toe.
Lock the steering column by installing the Steering Column Anti Rotation Pin tool J 42640 into the underside of the steering column--Aurora
Steering gear mounting bolts--Aurora
Power Rack & Pinion Steering Gear Heat Shield Removal & Installation To Remove:
  1. Raise and support the vehicle.
  2. Remove or disconnect the following:
    • The stabilizer shaft links.
    • Rotate the stabilizer shaft downward.
    • The electrical harness clip.
    • Power steering gear heat shield mounting bolts.
    • The heat shield.
To Install:
  1. Install the power steering gear heat shield.
  2. Install or connect the following:
    • The mounting bolts And torque to 89in.lbs.(10 Nm)
    • Rotate the stabilizer shaft into position.
Figure of heat shield removed from above rack bolts with location shown
Feb 11, 2011 | 2001 Oldsmobile Aurora
How to remove and replace radiator on 1998 ford taurus
  1. Disconnect battery ground cable.
  2. Remove the battery.
  3. Remove clip retaining constant control relay module and position module aside.
  4. Remove battery tray.
  5. Remove radiator cap.
  6. Raise vehicle on hoist.
  7. Remove radiator splash shield.
  8. Drain engine cooling system.
  9. Remove radiator mounting bracket assembly.
  10. Remove lower radiator hose.
  11. Partially lower vehicle.
  12. Remove upper radiator hose.
  13. Remove radiator overflow hose.
  14. Remove upper A/C condenser core retaining bolts.
  15. Remove upper A/C transmission oil cooler tube clips.
  16. Remove upper transmission oil cooler tube (7C410) using 3-8 inch fuel line disconnect tool 310-041 (T90T-9550-C).
  17. Raise vehicle on hoist.
  18. Remove lower transmission oil cooler tube clips.
  19. Remove lower transmission oil cooler tube using 3/8 inch fuel line disconnect tool 310-041 (T90T-9550-C).
  20. Remove transmission oil cooler bracket and position transmission oil cooler aside.
  21. Remove lower A/C condenser core bolts and position A/C condenser core (19712) aside.
  22. Remove radiator support bracket.
  23. Remove radiator.
May 07, 2010 | 1998 Ford Taurus
I have a 2008 Triumph Sprint ST 1050. How do you adjust the foot gear change selector ?
There are 2 nuts on the bar from footrest to gear-change, 1 has a right-hand thread & the other has a left-hand thread.
Undo them both then turn the bar to alter its length thereby raising & lowering the gear-change height
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
May 03, 2010 | 2008 Triumph Sprint ST
2003 grand am-rear window lowers but wont raise-motor working both directions-can raise window by hand-dont know about cable operated-diagrams?
Sounds like the two tabs that connect the window glass to the motor hardware may be broken off. This happened to me before. It will let the window go down because gravity and the weight of the window let it fall but when you try to close the window it is only getting pushed up with either the front or back tab on the window jamming it in the tracks and not letting it go up.
Feb 13, 2010 | 2003 Pontiac Grand Am
The blade will no longer raise or lower on my Jet
Make sure the set screws in the handle and gear are clamping against the shaft..
Jun 17, 2009 | Jet Saws
NO paper light
Something worth considering: Check that there is enough slack in the paper tray to allow the gears at the front to lift the paper to the pickup wheel. I've found that on my firm's 8860DN, the paper tray being set too "tight" can cause too much friction, preventing it from moving. If you can raise/lower it by hand (using the gears on the side of the tray), you should be fine.
Dec 04, 2007 | Brother MFC-8860DN Printer
Nikon Microscope Alphaphot-2 Ys2-t 4 Objectives Cfwe 10xa/18 Eyepiece E100 1.25 Logo
292 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
William McMath
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
