Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Good nighte dear my name is essam from egypt kind of my router is Linksys RT31P2 Broadband Router my problem is when i,m conected dsl to router the phoneline is cut i need help plz
    Problem Solver:
  • 13 Answers
You Need A Antenna
Posted on Jan 24, 2009
  • 59 Answers
Ask ur ISP to provide u with some new adsl splitter & filters. i am sure after that it wil start working fine
I want description on how to connect twp linksys wrt54gr routers to the same DSL modem ?
Hi
I understood that , you need to connect router with DSL modem .
1- connect router with pc by cable
2- change your IP address to be DHCP,
3- open internet explorer and type the default IP for the router , usually be 192.168.1.1
4 -it ask you about used ID and Password insert the default one usually be : admin and password : admin or password
5-choose from left menu wlan, and insert your user name and password ,chose the type of connection ppeo broadband .
to this step it must work correctly if you click connect
Apr 25, 2011 | Linksys WRT54GR Wireless-G Broadband...
My WRT54GC won't let me into the control panel. I've looked up the solutions for hours, and i can't get it to work. I'm using a MBP and a HP Pavillion dv6000, and it's the same with both of them. If i...
If you connect the router (WRT54GC) to your broadband modem does it then allow wireless action? Your router has an Internet address. It is 192.168.1.1, in all probability. Check your manual to be sure. Access to the control panel is through this address. You must log in to the router then set up the Wireless, the SSID (the name you give your network) and any security you set up. I prefer the WEP-PSK[TKIP] as it's easiest. Other things with the router, settings and such, pretty much are set automatically, so once security is set you should be good to go. Good luck !!!
Nov 11, 2009 | Linksys WRT54GC Compact Wireless-G...
Cannot connect to wireless Broadband Router
Call linksys technical support. If they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Connectivity
Hi Joe,
That just depends on how you want to connect with your laptop.
If you need wireless access, then you have to use the WRT54G, because the RT31P2 has no wireless capabilities.
If you are connected via ethernet cable, then you can simply take the WRT54G out.
If you like to read up on different scenarios, here is my favorite page.
Enjoy!
Jan 07, 2009 | Linksys WRT54G Wireless-G Broadband Router...
Vonage linksys router(RT31P2) s
change cable and also retart the router.
check power supply earthindg is properly.
if u have 2 lines one of fax so may be that reason u get disturbance.
Nov 01, 2008 | Linksys (RT31P2) Router
Do i need a modem for my linksys WRT160N Broadband router of enable to connect to my dsl, or can i connect directly my dsl cable to WRT160N Broadband router. Thanks in advance
Greetings,
You need to have a separate DSL modem
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 29, 2008 | Linksys Wireless-G Broadband Router
Not conection!!!!
Try turning off your cable dsl modem and restarting it. Many isp's use dhcp to assign IP addresses, your router may not have been assigned one if the modem hasnt been restarted. Also try powering on in this order: Modem, router, pc.
Feb 11, 2008 | Linksys Wireless-G Broadband Router
Wireless Connection
You didn't specify if you're using DSL or Cable internet.
With DSL, keep in mind the software on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer1.gif that has the software installed (verizon1.gif, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Jan 09, 2008 | Linksys Wireless-G Broadband Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
