Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP Officejet 7310 All-in-One Scanner problem
Help! After a month of working wonderfully, I came into the office one day and the 7310 tells me I have to reinstall the HP software. I don't know what happened overnight with it. After re-install, scanner only works on the glass - no longer taking from the feeder. Also scanner pop-up message keeps saying it's busy. Everything else still works fine. Company IT is no help, contracted HP rep is worse - he broke my last HP officejet. Anyone have insight to this problem? Thanks!
  • 2 more comments
  • Christine Parke Jul 11, 2007
    Thanks Tonerman for trying to help! I should have added that I acquired this all-in-one from an employee that was laid off. IT doesn't keep track of equipment so packaging and receipts are history. Do you think this could be a firewall problem?
  • pkopko Oct 16, 2008
    When I attempt to scan, 7310 says I have to install software before scanning will work. Worked fine for a year or more. All other functions work, and scanner works when accessed via browser.
  • kitchengod54 Oct 30, 2008
    I have exactly the same problem. I've reloaded that software several times. Has anyone found an actual solution? Taking it back is NOT going to solve the problem. I'm looking for a REAL solution such as a software patch or update.
  • Anonymous May 01, 2009
    I have the same problem with scanner, will not scan to computer. Tells me I need the software. Contacted tech support, told me where to go & install complete installation, didn't help. So I uninstalled everything & then went on line & reinstalled, nothing, same thing.
I had this problem with my 7310 and again with my L7780. Never got scanner on 7310 to work except from browser, but when I got my L7780, the CD that came with it would not install the scanner properly. I went to HP.com and downloaded the installation software (300+MB), installed the printer using that, and all problems were solved. You would think that HP could figure this out, but I gave up after hours on-line with them and more hours on the phone. Good luck.
Posted on Mar 15, 2009
  • 62 Answers
If the HP service cant help, then try to get a exchange, the machine usually have a warranty.
Posted on Jul 11, 2007
SOURCE:
I now have Windows 7 and cannot get 7310 officejet to work as scanner. The HP Solution Center does not show up. Help
go to hp.com and look under printers and look for yours. Under the printer page, look for drivers. hope this helps :)
Dec 28, 2010 | HP OfficeJet 7310 All-In-One InkJet...
HP office jet 7310 all in one. when trying to fax it says scanner failure. Turn off power and restart. This accomplishes nothing. Suggestions?
This means that there is an internal failure of some kind (e.g. the scanner is stuck). Be sure that the shipping lock has been removed and try again. HP is very good about support, try contacting them through their website or by phone.
Good Luck!
Feb 05, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Disable scanner or uninstall scanner function
Did you tried selecting xerox documate scanner as a default scanner, i think before you uninstall hp 7310 you should try that
Aug 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My Office Jet 7310xi scanner failure
Does it scan from either the doc feeder or from the flatbed itself?
Can you COPY a page?
Are you using the buttons on the printer, or do you work from HP director?
Mar 29, 2009 | HP Officejet 7310 All-In-One Printer
HP Officejet 7310 - Scanner Failure - Can't Remove ADF
These printers are notorious for having bad scanners. The fix will not last long. Replace the printer.
Mar 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
see here for the drivers and software
first you have to select the correct model from the page and then your windows system, and finaly you get the software downloads
Click Here
Jun 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
981 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
