Question about JVC Kw-nt300 Car 2 Din Cd/dvd/ipod/mp3 Usb Player Navigation Receiver Bluetooth
Jvc nt300 microphone not working - JVC Kw-nt300 Car 2 Din Cd/dvd/ipod/mp3 Usb Player Navigation Receiver Bluetooth
Is there an external battery on the JVC MZ-V10 microphone that needs to be changed from time to time ? What is the little button for on the microphone?
The JVC MZV10 Stereo Microphone is an external microphone that's compatible with JVC HD EVERIO camcorders that feature an accessory shoe and a mic input with plugin power capabilities.
Mar 05, 2014 | JVC Audio Players & Recorders
JVC KW-NT 300 get a startup error
Wow i just had the exact same thing happend to my deck :( any solutions?
Apr 16, 2013 | JVC KW-NT300
I have this JVC RX-6010V Receiver, how can I connect my microphone to the unit?
Get a microphone (with a) preamp and follow ITS instructions. It only accepts RCA Line Level analog signals.
Jul 05, 2011 | JVC RX-6010V Receiver
JVC MV-P612U Professional Microphone Wiring to XLR
The MV-P162U is a stereo mic designed to plug into a JVC professional camcorder. dates from the 1990's and was very expensive.If the 6 pin plug has not been cut off, and you can get a socket to fit, then going clockwise around pins (or wiring side of socket) from the locator.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
suggest a small breakout box. tested it with a 9v battery - the drain is 14ma. could run from 12v via a 285 ohm (approx) resistor with a 47uf cap across the mic supply.
Apr 15, 2011 | JVC MV-P612U Professional Microphone
Is a dual XLR adapter available for the MV-P612U JVC stereo mic.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
May 05, 2010 | JVC MV-P612U Professional Microphone
JVC Everio GZ HD-40's external microphone problem
I have the GZ-HD40 and have tested the scenario below.
The problem is that the Microphones you are using are Mono, not Stereo. If you look at the plug on the end of your microphone you will see it has only two connections, the screen and the tip. For a Stereo mic it needs three connections screen, sleeve and tip, much like your headphone jack.
I know this is going to sound a bit nuts but use a set of head phones as a microphone. You will notice the left speaker acts as the left mic and the right speaker as the right mic.
Use microphone JVC MZ-V8 Stereo microphone and you will see that it has the three connectors as I have stated above.
Hope this helps.
Sep 03, 2009 | Video Cameras
My computer isn't detecting my new microphone?
Check if its plugged in the MIC port or the Headphone port.
Jul 06, 2009 | JVC MV-J3BK Microphone
JVC Kw-nt300 Car 2 Din Cd/dvd/ipod/mp3 Usb Player Navigation Receiver Bluetooth Logo
24 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
