Question about Tappan MEF500 Electric Kitchen Range
Oven problems with GE p2b912dem ge profile oven. Do you know if this range has frequent problems. I am still with the period where i can return stove. Sears is going to replace it but it is taking at least 3 wks to do so. I take this to mean that there is so much demand for stove that GE cannot keep up or that that there are so many problems that they are slowing production of them. Any thoughts.
    President:
  • 1,214 Answers
What problem are you having? GE builds a good product, so it may be that Sears is replacing to make you feel more comfortable that your getting a good unit. As for delivery time, all the manufacturers are cutting back production, and inventories are shrinking, which will cause longer deliveries for items such as this. And, the long delivery may be no more than a scheduling problem with the warehouse, or a combination of availability and delivery scheduling.
Posted on Jan 24, 2009
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
MY GE PROFILE RANGE OVEN DOOR POPS OPEN WHEN THE OVEN LIGHTS AND IT HAS A SLIGHT GAS SMELL
I have the same problem and GE has a technical memo out on this. It requires a programming change. Right now, I am trying to get GE to fix it at no charge, but so far, no luck.
Aug 21, 2010 | GE Profile JGS968 Gas Kitchen Range
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Dec 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't light GE floor range profile model
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
hgdhgd
Dec 19, 2009 | GE Profile JGS968 Gas Kitchen Range
Ge profile range door wont close
was the door removed during delivery? Hinges not being fully seated can cause this. also check to see if the lock is striking the door liner, it should line up with a slot in the inner surface of the door and not touch anything unless the oven is in self-clean
Sep 01, 2009 | GE Kitchen Ranges
I was cleaning my GE profile convection oven and after the 3 hour cycle, an error message F 1 started flashing, and the oven started beeping.
We frequently see this symptom due to a failure in the electronic range control (ERC). We repair a lot of these.
- www.fixyourboard.com
Jul 24, 2009 | GE 30" Built-In Single Electric Convection...
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
GE oven
Yup...I believe this may have been an issue with some GE models. I seem to remember a problem where some models had problems staying lit after preheating. The fix was replacing the oven thermostat. Now...the normal cycle for an oven lighting is just what you described. The glow igniter will glow first, followed by the gas valve opening, followed by ignition. Once the oven reaches optimum temperature it is normal for the gas to shut off and come back on to maintain oven temperature. However, if this is going on in a frequent fashion with the oven never getting warm, your guess is probably a correct one. Good luck to you.
Jul 31, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan MEF500 Electric Kitchen Range Logo
75 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
