Question about Dyson Dc34 Animal Handheld Vacuum With Longer Run Time For Pet Owners
Handheld dyson animal keeps dying out even though it charged
After being charged it will work for a few seconds and then die, you have to give it a few more seconds and it will work again briefly. Have washed filter and cleaned it all out.
rustysheriff
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
messstat
  • 365 Answers
SOURCE: Smelly Animal Bagless Dyson
You've cleaned up urine...somehow. To remove that odor, go to a local flea mkt or store that sells essential oils and buy "Citronella" (smells awesome) 1/2-1oz. bottle will last forever. Add 4-5 drops to the paper filter element - smell gone!
Good Luck
Posted on Jun 21, 2009
SOURCE: Not holding charge
Ok, folks.. I just posted my own problem with the battery not holding it's charge..but, we fixed it ourselves.. take the motor loose from the canister , remove the filter and in the back are two contacts.they are two screws at the bottom one on each side... get out your pencil with a GOOD eraser and clean those contacts!..clean around them both and the contact (silver spot at the bottom) and you're good to go!!
Posted on Oct 23, 2009
Vac Belts
  • 701 Answers
SOURCE: Dyson makes smell
You need to replace the belts. When they are worn they put off a smell. Here is the belt you need:
Dyson DC14 Belt
Posted on Feb 11, 2010
Dysonteam
  • 167 Answers
SOURCE: My dyson DC16 constantly shuts off even when
Hi its Darran at Dyson.
From your description of the problem, it sounds as though there is a problem with the battery.
Your DC16 will have been supplied with a 2 year guarantee. If it still within this period, please contact our Helpline on 0800 298 0298. However if your machine is no longer covered, a replacement battery can be purchased via our website at www.dyson.co.uk/store.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
My Dyson DC35 stalls. I've thoughly clean it, so it's not a clog problem
1st make sure battery is fully charged.
Next, wash the filter, just follow the instructions in the manual.
If the filter is clogged the motor will try to run but then cut out to protect the motor from damage.
Mar 30, 2015 | Dyson DC35 Handheld Vacuum
Dyson DC44 Animal Handheld Vacuum, keeps cutting out
dyson-dc44-animal-handheld-vacuum-keeps-ehecv3x4uj13pgwprhzrjmma-4-1.jpgThe battery falls slightly loose, so you have to fasten it securely to the body of the vacuum. I learned this from another user here on Fixya. He uses electric tape. I used one of those rubber bracelets that kids wear. Worked perfectly!
Mar 10, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
My Dyson DC35 handheld won't charge. The light on the charger won't even turn on and it is only 7 months old.
Hi my Dyson v6 is not charging it shows a blue light when we put it on the charger but in a few minutes the light goes off please help
Sep 08, 2013 | Dyson DC44 Animal Cordless Vacuum
My Dyson DC31 runs for a few seconds then cuts out and won't work at all. It is fully charged. We bought it just over 2 years ago and it has worked perfectly until now. It is clean and has no apparent...
Hi Jean, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC31. If it cuts out in use when it's fully charged, we'd need to take you through some quick diagnostic checks when you have the machine at hand. This will help our experts determine what may be causing the issue.
Please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 04, 2013 | Dyson DC31 Animal Bagless Handheld...
My handheld dyson is not working - initially it was cutting out after only a few mins then seconds now it won't work at all despite showing green light ??
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC31 Animal is only working intermittently. When fully charged, this machine should have a maximum runtime of 10 minutes, or 6 minutes on the maximum power setting.
There are several factors which could cause this, and to determine what's at fault we'd need to take you through some quick diagnostic checks when you have your machine to hand. The machine would also need to be fully charged, so please make sure it's had 3.5 hours to recharge before calling us.
You can reach our freephone customer Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US). Our experts will be happy to help further.
Best wishes,
Jack
http://www.dyson.com
Apr 07, 2013 | Dyson DC31 Animal Bagless Handheld...
Dc 31 animal: even when fully charged keeps cutting out. stop for a moment & it starts then stops. Filter cleaned & checked.
Sorry to hear you're having difficulties with your DC31 Animal. It's probably best if you get in touch with us directly, so one of our experts can run through some troubleshooting over the phone with you to identify the cause of the issue. They'll be happy to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 28, 2011 | Dyson DC31 Animal Bagless Handheld...
Dyson DC16 keeps cutting of after 2to3 seconds tried removing the small three leg resister and joint A and B together but still didn't work can any one help with this problem
Most likely it is your battery. the lith ion batteries die out over time. That is on of the symptoms of an old battery. Did you call Dyson? They have a 5 year warranty
May 06, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My dyson DC16 constantly shuts off even when battery is fully charged. I cleaned the filters to see if that was the problem. It only runs for a few seconds before it shuts off. It will run intermittently...
Kind regards
Darran
Jan 31, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Dyson Dc34 Animal Handheld Vacuum With Longer Run Time For Pet Owners Logo
35 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
