Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Red's are out of alignment and I can't fix them
Reds are off can't fix them with manual or flash focus, any ideas as to what the issue may be?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Its failure of convergence out IC and needs replacement of part or D board (what ever you feel easy)
  • Sony Master
  • 8,617 Answers
Replace the convergence ICs and the pico fuses you can get a convergence repair kit at the following link which is for the KP46WT510 But its the same one for your model. The kit contains the two convergence Ics all six pico fuses and four resistors. Plus free step by step instructions with pictures that show how to do the repair. Heres the link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Posted on Jan 24, 2009
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
I have a 2001 sony kp61hs30 that has always worked great. turned it on today, the blue and red do not match up. the flash focus button on the TV will not align the blue and red plus signs. Got any...
I have a 2002 sony KP61HS30 and the blue and red do not match up. I use the flash focus button and it does not align the red and blue plus sign. Have any suggestions?
Dec 11, 2010 | Sony KP-61HS30 TV
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
2007 ford focus rear door lock inop
i have a 1992 honda accord 4 door & the dash door display flashes red but the doors are close?
Mar 27, 2009 | 2007 Ford Focus (3 Door) Hatchback
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com.
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
Model 53fdx20bv2f012705
I have the exact same problem.......you just explained it a hell of a lot better than me. In the magic focus was red broken up, blurred and flashing as well as only 3 bars???
If you solved your problem could you please get back to me.
Thank you
Randy
gardner7768@msn.com
Apr 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 24, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Everything red is on fire with an ugly pink shadow!!
Todd, The fault could be in the red video amplifier circuit, and would require either a service sheet with voltages to measure, or an oscilloscope to observe waveforms and levels. It may just be faulty, noisy preset potentiometers on the circuit board, used to adjust various parameters of the colour system. If you are confident then go ahead and check these circuits. Another cause could be a fault in the CRT (cathode ray tube), or the magnets used for alignment. These require skilled knowkedge of what they do and one may have shifted.
Oct 22, 2006 | Zenith C27A24T 27" TV
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
