Question about Aurora Electronics AS1010TX Cross-cut Shredder
Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
Cutter will work for 1/3 of standard paper size and the go into reverse. Is a switch not working?
  • 432 Answers
I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
Posted on Jul 10, 2007
SOURCE:
Embassy shredder keeps running after it's done shredding. It won't stop running.
Hi Brenda:
My shredder, different make, occasionally has the same problem, especially when I try to put too many sheets of paper through at one time.
It happens because the paper jams in the cutter wheels and holds
a switch lever in the on position.
Step 1) Use the reverse switch (mine has one) to back the paper up a bit, then switch it to forward. Repeat this a few times and it might clear itself.
Step 2) If step 1 did not work, unplug the machine and use needle nose pliers, a small swrew driver, or any other handy tool, and remove all of the paper bits from the cutter assemble. Once this is done, it should work fine.
Jun 28, 2015 | Shredder Office Equipment & Supplies
How do i clear jammed cutter blades
Does the shredder have a reverse button ?
If it has, just switch between reverse and forward a couple of times.
If that does not work it may have to be dismantled and the cutters turned by hand as you pull the paper out. Disconnect the power first though.
Dec 17, 2014 | Office Equipment & Supplies
Its not working and shredder wont turn on
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and poke at any compressed paper wrapped around the blades - can take a while. Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 27, 2014 | Aurora Electronics AS1010TX Cross-cut...
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Doesn't work going forward only in reverse
sounds like you have a sensor problem. is it automatic reversing on jamb? if so sensor is defective, or there is a bind causing sensor to reverse only, a bent shaft could cause that
Apr 04, 2010 | Aurora Global AS501X-MS Shredder
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
Aurora Papaer Shredder circuit board problem?
It just sounds like a paper dust problem.
use canned air to completely clean all sensore.
Oct 23, 2009 | Office Equipment & Supplies
My Aurora AS1010TX paper shredder will not shred paper. It will work in reverse.
If you want to attemp to take the machine apart, there should be a small spoked wheel called a pulse sensor that runs through U-shaped black device.
Blow this out as well as all electric devices inside.
Sep 27, 2008 | Office Equipment & Supplies
Aurora as1010tx shredder won't run unless
you will probally have a tough time getting specs on a pc board from the manufacturer you will probally have to find a service dealer in your area that works on shredders or you will probally need to purchase a new pc board from the manufacturer if they still have one available or you may be able to find one online if you know the item number for a pc board replacement.
Oct 04, 2007 | Aurora Electronics AS1010TX Cross-cut...
Aurora AS1512X Cross Cut Shredder
Sounds like the cutter is jammed. Do you ever feed staples or clips in it? Will it reverse? If not, the power borad is burned out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 24, 2007 | Cross Aurora 15 Sheet Cut Shredder -...
Aurora Electronics AS1010TX Cross-cut Shredder Logo
258 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Vincent G
Vincent G
Jim Keysor
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
