Question about Vizio P50HDTV10A 50 in. Plasma HDTV
I can find where to conect my antena cable on a Vizio p50hdm
I just buy a VIZIO P50HDM and lost the manual so I can finf a outlet for the antena. I can see movies but not TV. When I turn it on I get a message saying NO SIGNAL.
Thank you,
Luis Carlos Sanchez
  • 1,077 Answers
Your TV is a monitor only. That means it does not have a tuner inside for an antenna. You may try a VCR for a tuner and hook up the antenna to that. Good Luck
Posted on Jan 25, 2009
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on Vizio P50HDM
Check you voltages before just swapping out boards. Although a YSUS is common for no picture, so is your upper and lower Y Buffer boards or the panel itself. Check youe -VSC voltage. Does it look like it is being loaded down? If so then your YSUS is not the problem. You can run the set with just the upper or lower Y Buffer boards untill the load is gone. That will let you know wich board to replace.
Jun 20, 2012 | Vizio Televison & Video
Anyone have a service manual for a Vizio P50HDTV20A?
I've with me the service manual you need; is for Vizio P50HDM; but I can't send it to you by this site as you know. If you send your email address to me by FixYa comment box, I'll send a copy of it to you by return mail. OK.
Jun 09, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
I have a Vizio P50HDM which will seem to turn on but It displays a small blue rectangle in the center of the screen with the message: "No Signal" I have tried pressing the input button but same message....
Your TV isn't detecting a signal on any input. You can have a bad connecting cable, or a defective source unit, (cable box, satelite reciever, DVD player....). Those are just a couple of possibilities, but a good place to start. Good luck.
Dec 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
643 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
