Question about Ricoh Office Equipment & Supplies
Ricoh mpc 3500 id sensor
Fixing the prob
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
  • 990 Answers
SOURCE: I have a ricoh mpc 3500, it works fine but i am
Hello sir; There are two way to get rip off the lines,# 1 , aat the end of the transfer belt there have a cleaning unit , clean up , if need to replace cleaning blade , change it. #2 , after you copy , pull out each drum unit check it out see which drum with the line on it, replace that drum unit.
Posted on Aug 15, 2009
newport74
  • 58 Answers
SOURCE: sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Posted on Feb 26, 2010
SOURCE: I have a Ricoh MPC
You may have to restart the Ricoh Fax Service.
1. Go to Control Panel>Administrative Tools>Services
2. Find the service Ricoh Fax Service.
3. Right-click on the service and click Restart. This will cycle the fax service.
4. You may close the Services panel.
5.Download and install the latest lan fax driver >>
http://support.ricoh.com/bb/html/dr_ut_e/re/model/mp35/mp35en.htm
Posted on Sep 15, 2011
murf427
  • 336 Answers
SOURCE: Ricoh Aficio MPC 3500 copies and prints are out of alignment
The software that came with the printer has maintenance solutions. It will tell you how to re-align the printing.
murf427
Posted on Oct 25, 2012
Ricoh MPC 3503 fails to recognis paper in tray 2. what could be the reason
There is a paper high sensor that might not be working . Try to restart the machine with the paper tray open to reset all tray sensors . If that does not work you are probably going to need a tech to make sure all paper sensor are working .
Aug 14, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh mpc 350 error school 972 what is the resion Ricoh mpc 3001 error code sc 972 how I can fixed it
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 31, 2016 | Ricoh Office Equipment & Supplies
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Jai un C3500 mp Aficio de Ricoh qui a sc erreur 792
finisher cable not plug into copier. I f you don't have a finisher don't worry about it or you need to remove bridge unit to get rid of code.
Sep 20, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Erorr problem code sc 336
No such error code. There is a 363. That is for a bad yellow developer unit.
Sep 09, 2014 | Ricoh Aficio Mpc 3500 Color Copier
ERROR CODE 400 ON MPC 2050/2020
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
The machine detects a High signal from the drum motor: CMY for 2 seconds after
the drum motor: CMY turned on.
• Overload on the drum motor: CMY
• Defective drum motor: CMY
• Defective harness
• Shorted 24 V fuse on the PSU
• Defective interlock system
2. Check if torque output value for drum motor is proper if not replace the unit.
3. Replace the drum motor: CMY.
4. Replace the 24V fuse on the PSU.
SC4xx: Image Processing - 2
No.
Type
400
D
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400".
The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than
the value (default: 4.5V) specified with SP3324-005 or less than the value (default:
3.5V) specified with SP3324-006.
• Dirty or defective ID sensor
• ID sensor detection surface dirty
1. Check the harness of the ID sensor.
2. Clean or replace the ID sensor.
• After replacing the ID sensor, input the ID sensor correction coefficient
with SP3362-013 and -016. For details, refer to "ID sensor board" in the
Replacement and Adjustment section.
3.
Check the spring at the PTR unit contact lever. (See "PTR Unit Contact Motor"
in the chapter "Replacement and Adjustment".)
4. Replace the BCU
Oct 31, 2013 | Ricoh Office Equipment & Supplies
murf427
Oct 25, 2012 | Office Equipment & Supplies
My four wheel drive went out on my pickup and i don't know how to fix it. How one know were i could start looking to find this problem
i had the same prob this week on my 98. if your lucky start with the top of your four wheel crankcase. there is a valve right on top that has four vac lines that plug in may be bad or stopped up. my prob was in my case its self. it wouldn't go in at all or it would kick out when it did. so it has to come out if that's the case..i found the most common prob is a stretched Chane. the next one was my prob i was lucky there. there is a round fork that controls your low hi two wheel a four wheel points.it has three plastic guides on it. so replace and your good to go. i fixed mine my self it wasent that bad, but for them two probs you well have to remove and split the case to fine out.
good luck tom
Jan 02, 2011 | 1998 Dodge Ram 1500 4WD
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
