Question about Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL Outup
Hi, I just purchased a clean used Uniden PRO510XL and would like to know if is possible to up the output on this radio and how high would it go?This radio is to be used on a taxi base in NYC. Thanks.
  • isaiasrho Feb 04, 2009
    Excellent input!, Thanks.
  • 39 Answers
The Uniden 510 xl is quite possibly the easiest and one of the loudest radios I have ever pumped up .Now here's the problem it's been atleast ten years since I've had the cover off one so I can't tell you which diode # it is you clip for the modulation I know that as your looking at it (speaker side up ) it's about halfway on the right hand side buy the audio transformer.Then you change the resistor buy the final transistor , you go higher until you get where you want it , going higher is going to bring your output wattage down ; I usually tried to get it down around two watts . By doing just these two things and maybe a little adjusting you should be able to deadkey 2 watts and swing to 18 watts with just that cheap stock mic. if you change the final transistor I've seen them swing to 35watts.They are fun cheap radios that when you do this no one beieves that that's all your talking on . Good Luck !
Posted on Feb 04, 2009
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL low output and "motorboating"
Hi
It sounds like your circuit board may have a bad solder joint. Sometimes during manufacture of the ciruit board, the joint could not be perfectly made. This will limit conduction and create heat which will worsen the effect over time. If you are familiar with opening and working with electronics then I suggest you remove the circuit board and inspect it for cold solder joints. When you find one, you can use a Cigar Torch type lighter to help reflow the solder easily. Out side of that, you mayu want to send it to a Electronics repair shop to do this for you. Let me know more and I will help. Good luck
Jan 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
How to add talkback to a uniden pro510xl
68 to 200 ohm resistor to the postive side of the speaker to board ground
Jan 28, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
I have a Uniden PRO510XL radio and a 48" single
then the antenna needs to be moved. antennas have to have a ground plane to get correct swr below 3... or there may be a bad ground. try moving antenna @ different angles to see if it changes swr's or even opening the door away or closer to the body will make it change. also check the insulator it should be on top. call if you need help
Dec 22, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just have uninden pro510xl (used), but don't know how to set the channel (progamming) so it can match with my handheld radio (i use motorola GP200). Thanks...
hi The uniden pro510xl operates on 11mtrs or 27mhz (cb band) the gp200 is vhf 136-174mhz so you will not be able to communicate through these radios you can only program within the specified frequencies hope this solves your problem
What do you clip to turn up the power on a uniden pro 510 xl new style
hi you cannot tweak anymore output power from these radios as ajusting any components will damage the rig ,they come factory set at 4watts tweaking it anymore will after prolonged use damage the finals /pa transistor so leave it well alone if its not broken dont fix it goodluck
Oct 27, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl transmitts slightly off frequency. Is there an adjustment for this?
Yes, you need a frequency counter to get IFfreq back were it needs to be. google cb shops in temple, tx
Aug 07, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Modification of frequency output of uniden pro 510xl
deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Feb 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL 40-Channels Base CB Radio Logo
516 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
