HOW DO I REPLACE THE INK CARTRIDGE IN A CANON MP 220
  • 24 Answers
Take out the printer head first, which is on top of the cartridges, hence freeing the way for them to be possible to take out. Each cartridge has a plastic thing at the end that you can gently push that will "eject" them slightly and you can take them out. Take old ones out, put in new ones in the right order, push gently and await the "click" that they are in place (see the little light also going on when they are in place), put back the printer head. Close printer.
Please let me know if this helped:)
Posted on Jan 27, 2009
Tip
How to extend the life of your cannon printers and recycle ink as well
The main problem of canon printers nowadays is that it has lifespan when the waste counters of the printers become full you can no t print anymore.
To fix this problem all you need is intravenous fluid hose,phillips screw driver, drill,empty container and a lot of guts
first things first is open your canon printer using the screw driver after opening you'll find a hose where the printer cartridge sits this hose has a black stripe on it and goes directly to a catching pad which is commonly know as waste pads. pull out the hose from the waste pad and connect the intravenous fluid hose after you've done it secure it with a glue stick, glue gun or anything. Now drill a hole on the back side of the printer cover the hole must be of the same size of the intravenous fluid hose. assuminbg that you have already done this.insert the hose to the hole you've made and cover back your printer. now find a container for your waste ink. then you are done
to recycle the ink that you've collected on your catching basin just filter the ink out with a cloth and refill the waste ink as black. i've been doing these for a long time already and saved alot of ink for my black cartridge. hope this helps
on Jan 10, 2010 | Computers & Internet
How do I print in color from Dell vostro 220 to HP Deskjet 6940 printer
1. Check if the printer has colored ink.
2. Check the settings. Make sure that the colored ink is activated.
3. Update the driver for your printer. Scan your computer with RadarSync.
Let me know if you have any questions.
David
Apr 08, 2013 | Dell Vostro 220 Desktop Computer
Finding compatible upgrade to cpu 870
Instructions
Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
Wait a moment. The cartridge carrier will automatically disengage.
Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
5
Carefully pull the tape off the new cartridge.
6
Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
7
Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
8
Close the printer's lid. Print a test page to ensure everything is working properly.
Jan 10, 2013 | Dell Studio XPS 8100 PC Desktop
Cannon pxima MP 357 no printing & search for e 5200 error to the manual user guide
error 5200 means the printer is unable to detect ink cartridge.
I do suggest you remove the ink cartridges from your printer. Examine the surface contact to where the terminals inside the printer touches. Clean this surface with clothe moistened with alcohol.
After that reinstall the printer and see if the printers successfully detect the cartridges..
Press the stop / reset or the cancel / resume button (the button with inverted triangle enclosed in a circle) hold it for about 5 seconds until the printer self restart.
ALPUG
If this will help, please give my answer some ratings!
Mar 25, 2011 | Computers & Internet
Lexmark x5470
Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
Want to put in new color ink cartridge, having a little difficulty
Whats the Problem? What kind of PC is it? Have you referred to the owners manual on how to replace it? You can also search the net for more information on how to install Ink cartridge for your brand. here is for HP http://www.ehow.com/how_4530876_install-print-cartridges-hp-deskjet.html
but you can search your brand and "how to install Ink Cartridge for (your PC)
Hope this helps
Oct 18, 2008 | HP Computers & Internet
How do you change the ink cartridge
Just open your printer's cover. The ink holder should slide to the center of your printer. Unplug the printer and remove then replace whatever ink cartridge you have.
Sep 23, 2008 | HP Computers & Internet
Lexmark x3430 need ink cartriage
This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
Lexmark - 24 Ink Cartridge - Color
Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
Lexmark - 23 Ink Cartridge - Black
Compatible with Z1400 series, X3500 series and X4500 series printers;
Sep 15, 2008 | Computers & Internet
Canon MX850 keeps saying Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. I...
It is possible that your ink cartridge is damaged. Try using an old ink cartridge that worked before and try to print again.Even if the ink cartridge you are using is full of ink, when sensitive electrical components are damaged, it wouldn't work.
You can also try using a different printer to rule out the possibility that your computer is the problem.
Sep 06, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
