Question about Panasonic KX-TG2356 Cordless Phone
Phone says I am too far away from the base--panasonic kx-tg2356s
My phone says I am too far away from the base, I can even walk into the same room as the base and be right next to the base and it still says I am too far from the base???
  • Anonymous Feb 01, 2009
    Message: "No link to base.  Move closer to base.  Try again.
  • Anonymous Mar 22, 2014
    I just purchased and it is fully charged - but when I walk around it dies and says too far from the base
Unplug the base unit and when you plug it
back in the handset should work
Posted on Feb 07, 2009
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
Both handsets tell me to move closer to base
Is the phone base near any microwave ovens, radios, televisions and other electronic products that could cause radio-frequency interference (RFI)? How far away from the base are you when it tells you to move closer to it?
Jan 07, 2008 | Panasonic KX-TG6502B Cordless Phone...
Panasonic kx-tg2730 my extra cordless phone (2) tells me i'm too far away from base (1) when i'm right nexr to it. how can i connect it to the base?
One of the functions of your handset is REGISTRATION or RE-REGISTRATION. It involves stepping to that command, pressing enter, then pressing the handset locator button on the base and the two units can link up.
Carl
Apr 09, 2011 | Panasonic KX TG2730 Cordless Phone...
We can only go 15 feet away from base station
the phone either has a limt as to how far u can go, or the reciver for the phone on the base is broken or malfunctioning.
Mar 08, 2010 | Panasonic KX-TG2740 Cordless Phone
#1. No link to base. #2. Short distance usage.
That sucks. I have a Panasonic cordless 5.8 ghz set that is probably 3 years old and I have not had any of the problems you are complaining about. You might be getting interference from a wireless router or even a baby monitor. Is the phone near a wireless router? Most of the newer phones automatically select the channel with the least interference. Try moving the main base to another room there is obviously something causing interference with that phone.
Sep 17, 2009 | Panasonic KX-TG9331T Cordless Phone
Our Panasonic system shows "No link to base walk closer" for any of the handsets even when 2 inches from the base. Seems the base has stopped communicating.
Often times when this happens try putting the phone back in the base unplug from the wall for about 30 seconds plug back in wait about a minute then try again. I have seen where you may need to also try unplugging the battery from the phone for a minute put it back in and place in the base. Its a communication problem with the phone to base connections and resetting the power often clears this up.
Hope this helps!
Aug 08, 2009 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG6071B - Feedback from base station
-Possibly the hands set is away too far and its base can't communicate.
Good luck & enjoy
Mai
Oct 23, 2017 | Panasonic KX-TG6071M Cordless Phone
Interference on cordless Panasonic phone
The wireless signal is most likely your culprit. Wireless-B and Wireless-G signals operate at 2.4GHz frequency, which is the same that many cordless phones use.
Some wireless routers will allow you to change the channel that they broadcast on -- that might help your interference problem slightly, but it probably won't make it go away completely. Your best bet is to keep the cordless phone a good distance away from the computer and wireless router (if not in another room, at least on the other side of the room).
Hope that helps!
Mar 09, 2009 | Panasonic KX TGA271B Cordless Expansion...
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
PANASONIC KX-TG2431 CORDLESS PHONE
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
Panasonic KX-TG2356 Cordless Phone Logo
725 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
