Question about Daewoo Heating & Cooling
Daewoo Air Power Z 5.5-instructiunii - Daewoo Heating & Cooling
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
Daewoo electric dryer is stuck on "cooling"
-You mean it's working but Only cold air...?
-If so. Possibly the heater element is burn out.
Good Luck
Mai
Oct 11, 2013 | Daewoo DWRWE33WS Front-Load Electric Dryer...
When i plug in my Daewoo air conditioner the socket lights up but when i press the power button it does not work
Sounds like you have a plug that has a breaker built right into it. There should be a button to push right on the plug to reset it.
May 11, 2011 | Daewoo DWA-146R Air Conditioner
WHAT IS CORRECT TIMING MARKS FOR TIMING BELT INSTALLATION. 2000 NUBIRA 2.0 DOHC AND CRNKSHAFT MARKS. Thanks Joe
TIMING BELT
Removal
Disconnect negative battery cable. Disconnect intake air temperature sensor connector from intake air duct. Disconnect the air intake tube from the throttle body. Disconnect the breather tube from the valve cover. Remove resonator from throttle body. Remove air filter housing.
Raise and support the vehicle. Remove right front wheel. Remove right front splash shield from wheelwell. Remove serpentine accessory drive belt.
Remove crankshaft pulley bolts. It is NOT necessary to remove crankshaft sprocket center bolt. Remove crankshaft pulley. Lower vehicle.
Support engine assembly from above with Support Fixture (J-28467-B). Remove engine mount bracket from timing belt end of engine.Remove power steering hose clamp bolt, and position hose away from timing belt cover. Remove front timing belt cover. Using crankshaft center bolt, rotate crankshaft one full turn clockwise (as viewed from timing belt end of engine).
Align mark on crankshaft sprocket with notch at bottom of rear timing belt cover. See Fig. 4 . Align camshaft sprocket timing marks with notches on valve cover. See Fig. 5 .
CAUTION: Engine damage could result if camshaft sprockets are not properly aligned with notches on valve cover.
Loosen the automatic tensioner bolt. Use an Allen wrench to rotate tensioner and relieve tension on timing belt. Remove timing belt.
Fig. 4: Aligning Crankshaft Sprocket Timing Mark
Courtesy of DAEWOO MOTOR AMERICA, INC.
Fig. 5: Aligning Camshaft Sprocket Timing Marks
Installation
Ensure crankshaft and camshaft timing marks are still aligned. Install the timing belt. See Fig. 7 . Turn the timing belt tensioner counterclockwise to tension the timing belt. Turn tensioner until the pointer aligns with the notch on the rear timing belt cover. Tighten automatic tensioner bolt to specification. See TORQUE SPECIFICATIONS .
Using crankshaft center bolt, turn crankshaft clockwise (as viewed from timing belt end of engine) 2 full revolutions. Ensure timing belt tensioner pointer is still aligned with notch.
If timing belt tensioner is correctly aligned, install timing belt cover. See Fig. 3 . Install the engine mount bracket on the timing belt end of engine. Position power steering hose in place, and install clamp bolt. Install crankshaft pulley. Install serpentine accessory drive belt.
Install right front splash shield. Install right front wheel. Install air filter housing and resonator. Connect air intake temperature sensor connector. Connect negative battery cable.
Fig. 7: Identifying Timing Belt Routing
here
http://www.2carpros.com/questions/daewoo-leganza-2000-daewoo-leganza-timing-marks
Feb 17, 2011 | 2000 Daewoo Nubira
My daewoo cielo (nexia sedan) AC is not working.only fan is good
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Daewoo Heating & Cooling
I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
My air conditioner Daewoo DWC-100R keeps tripping the switch on power bar ... I just purchased it second hand and was assured it was in perfect working order. I am 65 yrs. old female with no knowledge of...
Have you tried to plug it directly into the wall Maybe the the power strip you are using is not able to handle the amps needed to run air cond. If thats not it you have a short to ground that needs to be checked out.
Jul 12, 2010 | Daewoo DWC-100R Air Conditioner
Daewoo airconditioner not working
Try reset power to the unit and see if that will take care of it.
Mar 26, 2009 | Heating & Cooling
Heating & Cooling Logo
236 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
