Question about Mountain Shimano Deore Bicycle Shifter/brake Lever Part 100
8speed lx shifter to xt shifter
I'm changing out bad shimao lx shifters to xt shifters. Do I need (have to) run a new cable thru the shifter and thru the frame and down thru the derailer or will the shifter **** apart.
    Scholar:
  • 34 Answers
It depends.. Shifter cables are standard and the same one would work for both LX and XT shifters. If the old cable is full of grime etc, it is a good idea to run new cables - it will give you a smooth easy shift.
I am sure if you check www.shimano.com you will find the manual for your model of shifter. Replacing cables is pretty easy.
Posted on Apr 19, 2009
Tips on installing the 7 speed revoshift sis shifter
Obviously, you must remove old shifter. With old cable removed, make sure you derailleur is on the smallest gear (7). String cable through cable housing, checking to see if there is any tight spots. The tight spots are places in the housing where the cable doesn't move freely. These are rust or bad spots in the housing, If you have a bit of problem, put some oil in the housing work it back and forth. If you have several problems consider replacing housing.
Now back to the installation, you gave the cable through the housing, set shifter on 7 or highest gear. Simply tighten cable at the derailleur. Tighten the derauiluer cable bolt. Check your work by running through the gears, if shifter doesn't shift thru all gears, check for slack in the cable. If slack, redo the operation again. If you continue to have problem, consider your local bike shop for assistance.
Nov 02, 2014 | Cycling
1990 honda accord lx is stuck in drive. i can move the shifter but it won't change gears. can't get it in park or neutral only drive works. figured out i can restart engine if i hold the shifter...
if you open up the hood and look on top of the transmission you will see a gold colored arm connected to a rod or cable this cable or rod probably came dissconnected or broke just rech in with some channel locks and move it possition by turning the gold rod shaft coming out of the transmission. it might not be gold it might be black depending on how dirty the engine is. if you have some one sit in the car and move the shifter you will see what needs to be moved. hope this helps
Aug 25, 2011 | 1990 Honda Accord
Ive a new rear deore unit cable and housing etc. where does the cable secure in the shifter unit? I can see a small metal arch but cant figure where the end of the cable actually fixes
Not a great picture but if you follow the arched groove back from the cable-housing guide it leads to a little hole. THAT is where you stick the cut end of the cable.
http://techdocs.shimano.com/techdocs/index.jsp
Accounting for physical differences, this should get you going.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Jun 21, 2011 | Shimano Deore Xt Thumb Shifters 7...
My Shimano Deore DX mountain bike up / down shifter is malfunctioning. Any help will be appreciated.
Maybe start here and if you can't figure it out, take it to a Bike Shop. Ther's only so much useful mechanical advice one can remotely lend with no details.
Jul 03, 2010 | Shimano Deore Xt Thumb Shifters 7...
Do i need to dismantle the shifter to put in a new cable
No, there's a little hole in the metallic base where you should be able to see the lead anchor end of the cable...
Move the shifter to the position that feeds the most cable out.
Disconnect the cable at the derailleur end. Pull the cable housing away from the shifter lever so you can see the shifter wire and push the cable into the shifter. You should see the cable end start emerging from the opposite side of the shifter. Pull it all the way out but make sure you take note of its routing to its derailleur.
Lube a new shifter wire and pass it into the shifter, through the housing, everywhere else it passed and reattach it to the derailleur.
Feb 19, 2010 | Shimano Deore Xt Thumb Shifters 7...
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
How do I replace rear shifter cable in shifter lever? Older Shimano Deore XT
ok this is a little hard to explain in words but the important thing is to make sure the chain is on the biggest cog, pull the cable through the deralier tight and fasten. don't pull it too tight however. you may need to fine tune using the h/l screws but if it was in tune before then it shouldn't need too much adjustment.
Oct 03, 2009 | Shimano Deore Xt Thumb Shifters 7...
XT shifter will not shift
This link should help:http://www.parktool.com/repair/byregion.asp?catid=53
Sep 01, 2009 | Shimano Deore Xt Thumb Shifters 7...
Mountain Shimano Deore Bicycle Shifter/brake Lever Part 100 Logo
639 people viewed this question
Top Mountain Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
