Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Western Digital 250GB External Hard Drive not working
There is power to the unit, but is not read by computer when plugged in.
  • 38 Answers
There are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Posted on Jan 28, 2009
I have the Western Digital My Book Essential Edition 250GB External Hard Drive. I have moved and lost the power cord. I purchased the DYNEX 500ma Universal AC Adapter as a replacement. When I plug the...
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Sep 15, 2011 | Western Digital 250GB MyBook External USB...
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
Output: 12VDC / 2A
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
I cant copy to or defrag my western digital 250gb external hdd I have scanned for viruses malware and adware It will read from it but after a while it always says theres a delayed write failure and or an...
Go to Start, Control Panel, Power Settings, and look in there to see if you have a power setting that puts your hard drive into a semi-active state or sleep after so many minutes of non-use.
Jan 15, 2010 | Western Digital 250GB MyBook External USB...
I cannot retrieve my files from the wd 250gb
First instinct is that your drive has failed. I would remove the drive and insert it into a system to test. If it works, then it is the housing from the external drive that failed. If the drive does not work once inside your system, then the drive is bad. Good luck.
Jun 04, 2009 | Western Digital 250GB MyBook External USB...
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
1,256 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
