Question about Electrical Supplies
Have a coleman 1350 powermate does not put out any power
Have a 1350 coleman powermate that quit putting out power have put on new reset button for it was poping that before it quit putting out power
  • 13 Answers
SOURCE: no power out put
this may sound silly, but check the reset breaker buttons
Posted on Sep 20, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
  • 5603 Answers
SOURCE: coleman 6750 powermate with yamaha mz360 electro
One of two things:
1. The rotor has lost all the magnetism it needs to get started generating. It needs to have a tiny bit to get started.
I have used the system of a couple series 150 watt lamps between the generator and the utility power. Search Google for description of this method. I have used it and it works.
2. You have blown diode(s) on the rotor. They would have to be replaced. I have not found a source and had to make my own.
Posted on Nov 02, 2009
  • 905 Answers
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Posted on Jun 12, 2010
  • 221 Answers
SOURCE: manual for a coleman powermate electric power base series
Follow this link and then enter your model number. I hope this helps you out.
http://www.powermate.com/productmanuals.php
Posted on Jun 21, 2010
Where can I get owners manual?
go to powermate.com and click on the "manuals" button.
May 25, 2010 | Coleman Powermate Premium Plus 6250W...
Not putting AC power.
Try pushing the reset button if that does not work replace the GFI duplex plug with same rated plug these are known to break and where out. I believe it is a 30 amp duplex outlet Hope this helps and you can get them at any hardware store.
Apr 19, 2010 | Coleman Powermate Powermate 5000W...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
No output
you need to replace your breaker frist. than check your rotor ohm and than your stator for shorts. you may want to check the cover were the bearing is there is a metal ring that may have came out and hits your brush cover. look for black burnt marks
Oct 13, 2009 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6200 that puts out no elecietety
Here is a link to a general solution I posted some time ago.
If that doesn't solve the problem let me know.
Regards,
Carl
Feb 22, 2009 | Coleman Powermate Premium Plus 6250W...
Looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Feb 06, 2009 | Coleman Powermate Premium Plus 6250W...
No power out put
After checking all connections check for power from the end of the alternator. if there is no power it is either the diodes in the end of the alternators rotor or the capacitor has blown ( round barrel shaped device with four prongs on ) When changing capacitor make sure you get the correct size mesured in micro farads.
Sep 14, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
311 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
