Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
My bissell pro heat 2X will not work, no water or solution comes out, what can I do?
  • buthercup5 Feb 01, 2009
    The sprayers are clear, and I still do not get water or fluid out of the hose or the machine floor area
  • dirtyrugs Feb 04, 2009
    I have the same problem, at least I did. We got it at Best Buy and my wife, bless her heart, bought the extended warrenty. I returned it with the problem of not dispensing soap solution. Best buy replaced the water tank and low and behold that didnt fix it. so on the second try they replaced the tank again, the handle and the pump. Now low and behold it despenses the soap indescriminatly. I cant stop it. Now it is back at best buy for the third time.They said they would replace it. It has been 3 weeks and i have no shampooer.
Buy some CLR - Calcium, Lime & Rust Remover. Place about 8oz of it in the clean water bladder along with hot water. Fill it to the brim. Fill up the Applicator dispenser with plain water.
Place the streamer in the shower or an empty tub. Hold down the trigger and apply removable tape around the trigger, so that it's constantly in the spray position.
Power on and let solution run thru the device. Make sure the Applicator dispenser has some plain water in it.
Run all the water and CLR solution thru the machine (sometimes it requires 2 or 3 applications.
If this solution helped the save you the $200.00 cost of this steamer, please consider using my company, Async-Nu Microsystems, for your IT Service Support needs. We supply outstanding support to Governments and corporations. Visit our website at www.async-nu.com
Posted on Feb 01, 2009
I think the instructions should have the user rinse the solution passage with water. The soap probably clogged your spray nozzles. I had the same problem, I used a toothpick to poke to hole open again. The solution sprays only. I can't figure out why the water is not spraying out though.
Posted on Jan 24, 2009
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat 2X pet will not spray water.
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Oct 18, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
440 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
