Question about Tyan Thunder K8HM (S3892G3NR) Dual Opteron/V&3L/RAID Server Motherboard (S3892G3NR (THUNDER K8HM))
Tyan Thunder K8HM no POST
New Tyan Thunder K8HM, will not POST. Removed second CPU from socket 2 (along with associated memory), still will not post. Memory is correct for MOBO (PC2100, registered, two 1GB matched sticks), and is installed in the correct slots per the manual. This board has built-in VGA, but the initial POST beep does not occur (nor does any other beeping), and there is no video output (monitor stays in power-save mode). Have swapped memory with 3 other matched pairs, to no effect.
  • Adam Fugman Jul 11, 2007
    Turned out to have been a bad board.
    Replaced the board, and the new one came up immediately and worked.
  • 624 Answers
It sounds like you?re an experienced hardware guy so I won?t bore you with the basics. When I?ve gotten stuck on a new motherboard no-booting problem these steps have helped me: -Make this as basic a machine as possible. You don?t need much of anything to get the POST to display and anything else just adds more variables. -double check the processor and memory, ensure they are correct for the board. Make sure the manual is the correct one for your board. -Try setting the BIOS to the manufacturers ?Safe? settings or default settings. You might even want to pull the backup battery out, unplug the power supply and let it set for 30 minutes to void the BIOS settings. -Verify the power supply is working correctly, preferably with a power supply tester. If you can?t then try putting this power supply in another computer to make sure it not only turns fans on but really supplies the correct voltage needed to make things work. -Buy or borrow a pre-boot test card. This is a diagnostic card that plugs into a PCI slot of your PC and will give you a much better diagnosis of what is going on. You can usually pick one up for about $35. - Make sure your CPU fan is plugged into the right motherboard connector, the newer boards will check for the CPU fan. I would suspect that if this were the case you would see something on the screen but you never know. Last but not least you might actually have a defective board. Granted it doesn?t happen too often but I?ve had two or three dead out of the box over the past few years. Chances are if you?ve gone thorough all of this and relate the steps to Tyan support they will send you a replacement. And if the new board does the same thing then you only have two remaining variables left; CPU and memory. Good luck and if you have any other questions please let us know.
Posted on Jul 11, 2007
SOURCE:
I have a tyan s2882 mb with 2TB WD drive that it can't recognize. Specs say the MB supports up to 2TB..help
Motherboard may only support the 2tb drive with the latest BIOS firmware. Have you checked the manufacturer and downloaded the latest bios?
May 05, 2011 | Tyan Thunder K8S Pro S2882UG3NR Dual...
D5 error on MB durring POST
i am william too i forgot password dell2400
Oct 22, 2009 | Tyan Computers & Internet
SERVER RESTARTS AT BOOT UP AFTER INSTALLING PCIE GF8600GT DRIVERS
Load the computer in safe mode by pressing F8 before windows loads up. Once in safe mode, uninstall the drivers that you installed, reboot and download the latest ones from the manufacturers website.
May 04, 2009 | AOpen Computers & Internet
My motherboard (Tyan Thunder LE-T S2518) simply won't start. It is powered on, has memory and cpus installed but nothing happens. The power switch is in it's place. Network cable is plugged in, it shows...
first thing to check would be the CMOS jumper to make sure it's in not in reset mode. You'll probably find it near the battery on the motherboard. If it is in "normal" mode (or jumped across the right two pins) then you may want to check the battery itself. That's the easiest and quickest thing to check.
Secondly, do you get any beeps from the mobo when you turn it on? If not, and it's not your cmos jumper/batter, you may have a badly seated CPU or heat sync, OR a bad CPU all together. If you don't know a lot about cpu's and reseating them, you should bring it in to a tech to have that looked at. Otherwise, if you know what you're doing, I'd pull the heatsync/fan off the CPU, clean off the old thermal paste, put new on (use it lightly), and reseat it all. Then see what happens.
Mar 14, 2009 | Tyan Thunder LE-T S2518GN Motherboard
Please help. i need to download audio and video drivers for a tyan thunder k8w (s2895). where can i find them?
HI
CLICK THE LINK:-
http://www.tyan.com/support_download_drivers.aspx?model=S.S2895
ENJOY
RATE ME DEAR
HAVE A GOOD DAY
Jan 07, 2009 | Tyan Thunder K8WE Motherboard
No video at all
try first with one cpu and only one stick of memory in socket zero
if the video does not come on... try next to reset the bios .. clear the settings... it may be setup to search for a pci or pci-e video card in the bios
next try to test the wattage being pulled into the system at boot... should be over 200watts.. may indicate a power issure
are there any beep codes ... post codes or ... is there a single beep tone during power on to verify the motherboard is functional and checks out fine at self start...
[email protected]
Aug 22, 2008 | Tyan Transport TA26 Server
Manual to tyan s239001
Try This link to Tyan Archive Files.
http://www.tyan.com/archive/support/html/manuals.html
I think your board will be here.
Trinity KT Manual under Socket 462/A ( AMD Athlon/MP/Duron )
Mike @ Compurepair.
Mar 12, 2008 | Tyan Thunder n6650W Motherboard
Flashed the BIOs to Version 2.02 now it only powers on
Yes could be the problem. Flashing bios is always!! a risky business. Best you can do is check all the connections, ie reseat all cards and memory. If that doesn't work looks like new motherboard time unless you can get a new CMOS chip to fit the board.
Dec 12, 2007 | Tyan Thunder n6650W Motherboard
Tyan Thunder K8HM (S3892G3NR) Dual Opteron/V&3L/RAID Server Motherboard (S3892G3NR (THUNDER K8HM)) Logo
193 people viewed this question
Top Tyan Computers & Internet Experts
Ekse
Marvin
Marvin
Lawrence Oravetz
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
