Question about Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat
Key will not go into ignition
We successfully put scooter into operation. After taking key out, it wil not go bACK IN. Wehave tried many times. There seems to be a spring loaded, brass colored piece down in the ignition that blocks the key entry.
  • 4 more comments
  • jbmbnafl Jan 25, 2009
    WD40application & exercizing spring loaded[obstructing]object did not help.Actually the spring loaded member is below 2 stationary pins which correspond to grooves on the key.. It moves freely out of the way of the key when pushed but returns to an extended [obstructing]position when pressure on it is ended.
    Thank you for supplying the name of the spring. In view of the fact that this does not help solve the problem,however, I would appreciate a refund of the $10.00 fee.
    Thank you for naming the spring. In view of the fact that this does not help solve the problem , however,I request you refund the $10.00 fee
  • jbmbnafl Jan 26, 2009
    Steering little bit has no effect.
    Scooter Co. & Pride advise replacing the part.
    Sergeant:
  • 378 Answers
As replacing the part is very much necessary.i advise you to replace the part as to get it done perfect.
Posted on Jan 26, 2009
  • 11,896 Answers
Remove and replace ignition or remove, take apart and remove blockage.
  • Nate Stansfield
    Nate Stansfield Jan 27, 2009
    Best best is a replace
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    YES, YOU WILL NEED TO REPLACE THE PART!
    HERE IS A LINK TO YOUR PART
    http://www.monsterscooterparts.com/pride...
  • 15,935 Answers
If you don't feel you NEED the key, you could remove the damaged cylinder and install a switch that will do the same as the key.
But if you're going through the trouble of taking out the lock cylinder, you might just as easily replace it.
They may - or may not - sell parts to the public.
Some manufacturers only sell to authorized service centers.
Contact Information:
Corporate Headquarters USA
182 Susquehanna Avenue
Exeter, PA 18643
Telephone: 1-800-800-8586
Your Lock Cylinder needs replacing. They are sealed units and generally not serviceable by owners. There is no other help we can offer here.
Thank you for using FixYa - A fixya rating is appreciated!!
    Genius:
  • 1,199 Answers
Take to an Able person to repair!
    Sergeant:
    Champion:
  • 334 Answers
Get some graphite and squeeze some into the keyhole You might try some wd 40 first but you need to put some graphite in it afterwards to keep it from happening
Posted on Jan 25, 2009
  • 2,039 Answers
The best thing to do is if you can remove the ignition switch bring it to a locksmith he will fix that for you if you got broken spring inside if you play to mush inside you might damaged it and gonna have to change everything thank you good luck pierre
  • pierre laplante Jan 25, 2009
    i understand that you whant a refund when a part is broken it need to be change im sorry about it pierre
    Sergeant:
    Champion:
  • 435 Answers
Try moving the steering little bit and try inserting the ignition key.
Sometimes it gets lock.
  • 916 Answers
That spring you are referring to is the ignition cylinder spring. You will need to have a tech look at it in order to get it working again. If it is still under warranty I would suggest calling Pride Mobility.
Posted on Jan 24, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you tried spraying with WD40? Additionally, you may try to exercise the spring loaded pins.
Pls post back results. Good luck and thank you for using FixYa.
  • 19,396 Answers
That is the spring inside the ignition cylinder that has broken.
  • Ginko
    Ginko Jan 24, 2009
    Do not use any tool, you need to replace the ignition cylinder.
    Cintact Pride Mobilityto get the replacement part.
    See Contact Us.
  • 153 Answers
Use some sissors like sharp thing to insert inside and try then
  • nicra7 Jan 24, 2009
    try moving it with some sharp device
    tis is for temperory use to start only
    if u find it dificult there wil br the starting wire below the igition key putting box koin it bike wil start
Status button flashes 5 times. Scooter is fully powered but will not move. Brake is off, lights work, etc.
BEFORE U RING TRY THIS TAKE KEY OUT PUT FREE WHEEL LEVER IN FREE WHEEL THEN PUT IT IN DRIVE PUT KEY IN & TRY OT. Hi again get in touch with pride www.pridemobility.com or ring them 1-800-800-8586. They might B ABLE to help cheers if the electronics r the same as celebrity put freewheel lever in drive & remove key then :::: put it back & try it out good luck
Apr 18, 2016 | Pride Revo 3 Wheel Scooter
Moved free wheel lever to drive but scooter will not run
remove the key for a few minutes then put it back in it should work unless there is another problem good luck........one more thing u can try put lever in freewheel take key out put lever in drive and put key back should b ok ...cheers
Aug 15, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Beep code 5 keeps going off, the manual freewheel lever is in the drive position. Can I repair it?
Hi remove the key for a short while make sure freewheel lever is in drive & replace key & try it out. If this doesn't help take key out put freewheel lever In freewheel then put it in drive put key back & try again good luck
Apr 13, 2014 | Pride Mobility Products Go-Go Elite...
Can't put key in the ignition
try moving your steering wheel back and forth while trying key. I don't see how you could move the steering column, its usually bolted in very tight. If you can move your steering column, it needs tightened up immediatly!
Dec 16, 2013 | 2004 Cadillac Deville
Ignition is loose
sounds like a loose or damage ignition, if you are happy to get your hands dirty, it should be easy to fix / replace as needed, first thing you need to try is poping a small amount of WD40 in to the ignition key socket, this some times loosens the internal components with luck that will sort it. if not then look to see if you can find the screws / bolts that hold the cover in place, if you can then just open up, there will be a nut on the underside of the ignition that is probably loose, tighten that first, then check all leads are secure if not tighten / re solder or crimp on new connection. test to see if problem resolved, if so fine put back together and off you go, if not then you will need to take out the ignition and order a replacement, there should be product info sticker on it, i would check eBay for a generic ignition (much cheaper) once you have replacement install and of you go.
Sep 07, 2013 | Harmar AL100 Universal Scooter Lift
Cannot turn key in ignition to start car even after checking transmission and even rocking the car to make sure it is in park.
put key in ignition. tap back side of key with hamer or screwdriver etc towards the ignition. like youre trying to tap it further into ignition. not extremely hard but hard enough and it will turn. I promise you, it wil turn and start car, no problem. Marc
May 28, 2011 | 2004 Chrysler Sebring
My 323i was stored for 2 years. I am now getting it road ready and the passenger front, and both back doors wil not unlock. can you help?
Hi, try this as it may or may not apply to your model.Get in, open and close the drivers door, put key in ignition turn 2 clicks and take back out again, within 5 seconds, hold the 'lock' button in the middle of the key and press the 'unlock' button 3 times, then let go. Quickly repeat the lock and unlock button sequence on the spare key. All doors should lock and then unlock when it has worked.
Jan 24, 2011 | 1999 BMW 323 Series
Key broke off in key switch on a 4 wheeler. What is envolved in changing this out? does it take special tools?
i had the same problem on my scooter. I used tweezers to pull the key out and then i took the bottom portion of the key to ACE hardware store. They didnt think they could remake the key but the guy i worked with was awesome. he cut the new key and it started my scooter. worked perfectly and it only cost $2.50 !!!
Jul 18, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Key Does Not Work
It could be that chip inside key just went bad. Do u have a 3rd key? That works? If so take the 2 good keys and turn the igntion to run postion for 3 secs each then do the same for the 3rd key and this will reprogram it if the chip is ok. If you do not have 2 good keys then u will have to have a scan tool that will link up with PATS system and perform security access to reprogram it.
Feb 12, 2009 | 2005 Ford Taurus
Central locking
To re programme your key if your fob has three buttons is as follows. Turn the ignition key in quick succession from off to ignition on 4 times. You should hear a chime to indicate programme mode. Quickly remove the key and press the lock button followed by the unlock button. Wait until you hear the chime again and see if the fob works. If it does not operate the central locking, see if you can open the tailgate with the fob, I guess you have a three button remote? If it doesn't, repeat the above but quicker!! it should programme quite easily. When you checked the fuse, did you take it out? I suggest you remove the fuse and wait 30 seconds and put back in, get someone in the car to see if any doors respond to you replaceing the fuse. recheck the fob operation and the key, this maybe the answer.
May 31, 2008 | 2000 Ford Focus
Pride Mobility Products Pride Mobility Maxima 4 Wheel Hd Scooter with 55AH Battery & Charger + Flat Free Tires 22x18 Hi Back Deluxe Fabric Seat Logo
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
