Question about Optoma HD72 Multimedia Projector
HD72 No Lamp function after replacement.
Lamp light LED shows red, manual indicates lamp failure.  Replaced lamp, that didn't work, then replaced light driver.  No change, lamp still doesn't work. On power-up, no red LED and projector appears to start up, fan runs for about 10 sec, (no lamp light) and then fan stops running.  The projector appears to re-cycle and fan starts again for about 10 sec.  This repeats for a total of three times in about one min, then red LED lamp indicator lights up.
  • sa_douglas Jan 30, 2009
    Connections were checked and double checked & verified actual contact with posts on bulb (wore rubber gloves). Original bulb had less than 800hrs & new unit was purchased from reliable source. Any methodology to bench test both bulbs for functionality or continuity? At $300 plus for a bulb a third bulb isn't a viable option. Also, is there any significance on the three attempts to start when the unit is powered up? Is that a built in duty cycle of the projector that would indicate the type of failure similar to an OBD-II in a car?
    President:
  • 2,110 Answers
The projector is sensing the amp draw from the bulb and shutting down due to out of spec draw...replace the bulb.
Posted on Jan 30, 2009
  • Optoma Master
  • 19,396 Answers
Remove the lamp and put it back in place. Ensure all parts are well mounted after replacement.
Posted on Jan 24, 2009
  • 153 Answers
Check the boars inside if it is proper and proper supply is going on
inside the circuit
  • 10,594 Answers
Please double check connectors of main board because seems any connector is not plugged properly.
    Genius:
  • 1,550 Answers
This can be because the lamp replaced may be defective.
Also the connecting cables when replacing the lamp may be disturbed . You need to check the connection .
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
Lamp flashing, hd72 projector
In most projector menus there will be an option to reset the lamp timer, it's usually under the "settings" area of the menu. Try resetting the lamp timer and the light should stop flashing.
Jan 17, 2010 | Optoma HD70 DLP Projector
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Optoma HD72 Multimedia Projector Logo
412 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
