Question about Canon PowerShot Pro1 Digital Camera
The lens can not remove
It shows Lens on the panel
    Genius:
  • 1,019 Answers
The camera has a problem that will require repairs.
Posted on Jan 27, 2013
How to clean mirror and optics mitsubishi 73 dlp
You have to remove the lower panel on the back of your tv, then remove the light engine. Unhook the wires attached to the DMD board. Remove the DMD board. Remove the heat cink from the DMD board. remove the optical lens but don't touch the lens. There is a video on shopjimmy.com that shows the entire procedure. Takes 2 hours. The optical lens can be cleaned with an eyeglass cloth, same for the DLP chip lens. no wet solutions on lenses. Remove dust from other internal parts with compressed air in a can. Your picture will be clean and clear. Wear latex gloves and make sure you are grounded to prevent static electricity.
Feb 23, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Tip
Solution for nikon "lens Cover Error"
Nikon Coolpix S5/S6 “LENS COVER ERROR”
In this document I have given a solution to fix the problem most of the Nikon coolpix S5/S6 cameras face. At power –on it give an error “Lens Cover Error”
Before opening the camera I would suggest you to take a snap of each and every step. Because it will helpful while you are fixing the screws back. There are many screws which has to be opened. So better take a photo of each and every step.
IMP NOTE: Remove the battery before opening the camera. Use some antistatic strip to prevent the components from getting damaged Or Keep your feet touched to the floor such that your body remains grounded.
Follow the below steps in the given order:
Step 1> Remove the screws at the bottom of camera
Step 2>Remove the side screws
Step 3> Remove the side screws as given below .
Step 4>Lift the cover and remove the cables which connects the switches to the camera. These cables are fitted in a small connector. There is a tiny lock (present for few connectors)  on the connector, which on pulling it across its hinges, will open and the cable comes out easily. You need not pull it forcefully.
Step 5> Remove the screw as shown below
Step 6> Lift the screen as shown below.
Step 7> Remove the cables and screws as shown below.
Step 8> Lift the screen panel as given below.
Step 9>
Remove cables as shown below.
Step 10>
Remove the cables as given below.
Step 11> Remove cables.
Step 12> Remove cables
Step 13> Remove the 4 wires using a soldering iron.
Step 14>
Step 15> Removing at this stage is a bit difficult. You will have to open it cleverly. Lift it from the side as shown below.
Step 16>
Step 17>Below figure shows the lens cover and the stepper motor which controls the lens civer.
Step 18> To remove the stepper motor remove the screws as given below.
Step 19> Below figure shows the stepper motor used for lens cover
Step 20> Below figure shows the stepper motor which is used to control the lens cover. There is a small white switch on this motor. This Switch is used by the camera to detect whether the camera lens cover has is open or closed. When we switch on the camera the lens cover (which is shown in step 17) opens and in turn it presses the white switch show below. If the lens cover is unable to press this switch, then the error “Lens cover Error” flashes on the camera.
I would suggest 3 different ways to solve this problem.
1>     Fix some glue on the white switch shown in the below figure, such that it remains pressed forever. Because of this, camera will never give the error message. Remove the lens cover (which is shown in step 17) forever. You don’t  need it anymore. Now fix the below stepper motor back in the camera and follow the steps in the reverse order to fix the camera components.
2>     Buy a new stepper motor from the market. Its quite cheap. Fix it back in the camera. Here you need not remove the lens cover. Follow the steps in the reverse order to fix the camera.
3>     In this method you can open the stepper motor to fix the problem. Now follow the steps given below.
Step 21>
Remove the screws as shown below.
Step 22> Remove the gears one-by-one. See the placements because you have place them again in the right order.
Step 23>
Step 24> The gear shown below is the culprit. Remove it. There is a tension spring present inside this gear. Do remember the position of this gear before removing this gear. Its placement is very important.
Step 25> The spring is shown below.
Step 26> Now the switch shown in step 20 does not get pressed because of reduced tension of the spring. Increase the tension of this spring by pulling it in opposite direction. Place the spring back in the gear and follow the steps in the reverse order to solve the problem. Now because of increased tension of the spring, the lens cover will be able to Press the switch shown in fig 20.
Happy debugging
Mukesh
on Mar 25, 2009 | Nikon COOLPIX S6 Digital Camera
Petal lens hood is showing around the edges of shot
Apparently the lens hood is too narrow for the current focal length. Either zoom in to narrow the field of view or remove the lens hood.
May 02, 2012 | Cameras
PHILIPS DVD 3007. IT SHOWS NO DISC DISPLAY WHEN DVD IS INSERTED
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Apr 09, 2011 | Televison & Video
My camera cant take a pic it has f -- show on monitor and it show R 11 what should i do ?
Is this a Nikon digital? If so:
"F--" means there is either no lens attached or there is a non cpu lens attached. The "Rxx) is the estimated number of images that may be taken with the present media card.
For the lens: TUrn camera off, remove lens and carefully clean the cpu contacts on lens mount and lens itself with a cotton swab lightly dampened with pure water. DO NOT OVER WET THE CAMERA OR LENS. LEt dry thoroughly, replace lens and try again. Try manual mode. If there is a camera hardware reset buttion, try that....Good Luck!
Nov 14, 2010 | Cameras
My GPX PD808 Portable DVD Player
The reason the DVD player shows no disc is because the laser?lens is either weak or dirty.
If it is weak, i requires replacement,
to replace it,
get the appropriate screwdriver,
Unscrew the compartment underneath the player,
carefully detach the panel and remove the old lens and replace it with a new one.
Carefully fix the panel back and close the compartment.
Test it with a DVD.
If it is dirty, then all you have to do is to clean it with a DVD lens/laser cleaner.
Jun 12, 2010 | GPX PD808B Portable DVD Player with Screen
How to replace passenger side brake light bulb
The process for changing the tail light bulbs for a 2003 New Beetle TDI is relatively simple.
To remove the lens and gain access to the bulbs you first need to release the lens holder from inside the trunk by completely unscrewing the large plastic wing nut that is under a round plastic panel that's located almost directly behind the rear brake light lens.
To gain access to the plastic wing nut remove the round panel by gently prying it off. After this is done you release the lens by using something flat like screwdriver to pry and release the clip that holds the lens in place. Locating the clip: The rear fender has two seams that end at the light lens, the inboard seam (the one closest to the hatch)is where you want to insert the table knife to pry the metal clip that holds the lens in place.
Gently and carefully insert the flathead screwdriver directly at the seam and pry upward to release the lens. Once the clip releases pull the lens the rest of the way and remove the bulbs by turning the bulb holder sockets counter-clockwise. After this is done remove bulbs by slightly pushing down on the bulb and turning it counter-clockwise.
To reinstall is reverse of the removal the procedure. When re-installing take care to clock the lens where the metal clip and the lens protrusions end up in the same position as before. Note: you may need to assist sliding the lens retaining clip in with the screwdriver when reinstalling!
Good luck and thank you for using Fixya
Mar 08, 2010 | 2003 Volkswagen Beetle TDI
Sigma 500mm lens need to remove funges from inside lens,but funges not showing on photographs is it possible to strip
That is a manufacturer repair. While you may be able to remove the fungus, the fungus may have etched the coating on the lens and still show . The best way to fix that is replace those lens elements that are effected.
Oct 30, 2009 | Cameras
Display is black even after removing the lens cap
See my post of before. I just knocked the camera on the floor by mistake and it miraculously started working again after years. Shows it must be mechanical and not related to software.
Jan 28, 2009 | JVC GR-D50 Mini DV Digital Camcorder
L7 Camera Lens
Remove back cover. Once removed you will see four screws they need to be removed using a T6 screwdriver. After removing the screws carefully remove the panel. Turn the panel over and clean the inside of the lens cover. Use either a soft bristled brush or a lens cloth to clean. After cleaning reassemble and test it out.
Sep 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Canon PowerShot Pro1 Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
