Question about DeLonghi DDE50E Dehumidifier
How to use the dde 50 e
I have no instructions for the unit, how do I operate it?
Why is my soleusair dehumidifier model GL-DEH-50 say F2
Pipe Temperature Sensor Malfunction.
1.
Unplug the dehumidifier.
2.
Check the surrounding area
for possible reasons for sud-
den temperature changes.
3.
Wait 2 hours before plugging
the dehumidifier back in for
normal operation.
4.
If the "Error" is still indicated,
please contact customer
service. Call 1-888-876-538
Soleus Air SG DEH 70EIP 6 Operating Instructions Manual Error Codes...
Jul 31, 2017 | Dehumidifiers
Should the fan shut off when the humidity setting has been reached for model Frigidaire CAD504DWL 50-Pint Two Speed?
Thank you for your post, friend!
I see that your question is if the fan should shut off once it has reached the recommended setting. The fan will run even when the compressor cuts off so that air can pass over the sensor coils to check the humidity. This is a normal operation. I hope this is helpful. -Matt
Sep 12, 2014 | Dehumidifiers
How do I fix leaking dehumidifier?
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Jun 29, 2014 | Kenmore 50 pint Dehumidifier w/Electronic...
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
MY WHIRLPOOL DEHUMIDIFIER MODEL AD50GEUSW IS NOT PRODUCING WATER ANYMORE
This is like a mini refrigerator. Even though you can hear the compressor operating, there may not be enough Freon to cause the moisture to condense.
Sep 05, 2012 | Dehumidifiers
I need a manual for delonghi dehumidifier DDE 40E
go to the companies web-site or to www.onlinemanuals.com
Aug 07, 2011 | DeLonghi DDE40E Dehumidifier
I have lost the instructions for the danby premiere 50 pint dehumidifier. Can you please help me as I have not idea how to reset it. Is there instructions I can have access to on line
The easiest way to reset it is to Turn the unit Off and unplug it for 15 minutes.Then plug *** back in and turn it ON. During the 15 minute timeout, it should have had time to reset itself and revert back to the original factory settings. Now, you can set the controls, as you like.
Jul 18, 2011 | Danby DDR583R Dehumidifier
DDR30E operating instructions, need to know how to run unit? New unit didn't get instruction manual
The following link is to your Owner's Manual. You can download and print it for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR25E__DDR30E__DDR45E__DDR5011_manual_v3.pdf
Hope this helps you. Please let me know. Thanks.
Jul 02, 2011 | Danby Dehumidifiers
DeLonghi DDE 40E Ice Formation in Back After 30 Minutes Use
We've lost the manuel for the DDE.40E. Could we please get a copy or downloaded. Thanks
May 21, 2009 | DeLonghi DDE40E Dehumidifier
User Manual has no guidelines.
When you first turn on the unit it is set to 40% humidity which is the lowest the unit will accept. You can only move the up arrow from that point. The 63 you are seeing is the actual humidity. If you want 50% youo need to press up arrow till 50 is displayed. The manual for this unit is terrible. Just leave it as it is and it will attempt to bring it down to 40%. 30 to 50 is the recommended humidity range.
May 03, 2008 | Haier 65-Pint Dehumidifier
DeLonghi DDE50E Dehumidifier Logo
37 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
