Question about Lenovo MTQ45NK Motherboard Desktop Board Thinkcentre
Video card What video card to add
After installing new ATI HD4670 video card on my Gateway zx6810 I boot system hear no beeps computer powers on but screen is black
Hello
Is this new video card the only video source on the PC (i.e. there is no other VGA connections on the PC)?
Without knowing the make and model of the PC, I will list the most common issue when replacing the video card in a PC.
1. Connect the monitor to each available VGA connection and boot the computer - to see if any VGA output is working
2. When you find a working VGA output, go into BIOS and change the VIDEO settings to either allow BOTH the onboard and add in video OR allow the add in video only. Save the changes and turn the computer off.
3. Move the video cable to the add in video card, turn the computer on and see if the BIOS is using the new Video card
Nov 03, 2013 | Sapphire ATI RADEON HD 4670, (1 GB) PCI...
After computer turns on there is no start bar, no icons, and nothing even when i right click...
Try removing your video card if it is and add on card and not on board restart you computer after you have removed it not forgetting to enter setup and tell it to look for the on board video not the add on card and connecting the monitor to the correct VGA port for your on board video. Allow windows to load fully and configure the on board video then once this is complete shut down your PC re install your video card after doing so power up your system enter Bios once again change the setting back to look for the add on video card usually automatic, Save and exit if screen is still black after windows has loaded connect monitor to the add on video card as it has configured it back to the rightful settings. If your computer loads to windows on the on board videos right click enter properties and change back to the add on card and connect cable after confirmation as screen will go black and you should be seeing everything you should have prior to the problem arising. If this does not work then it could be a worst case scenario that your video card has malfunctioned and needs replacing/repairs if able to be usually not though unless it is a big dollar card that is upgradable. If all else fails try to use the windows repair feature to repair the installation of windows. I hope this helps
Sep 01, 2012 | Dell Dimension 2400 PC Desktop
Can I replace the video card or add a video card to my laptop Gateway MX3225 Notebook for a better one?
Video cards are normally built-in on the laptop motherboard and you cannot replace them or add a new one because there is not an expansion slot to add a video card.
Aug 12, 2012 | Gateway MX3225 Notebook
Can I replace the video card of my laptop Gateway MX3225 Notebook for a better one?
Add another video card to my Acer T108-UA381B to have two displays but system only see new card. Does not recognize the bus video
most desktops disable on board GPU in favor of the better add-on card. Your best bet is get an add on card with multiple outputs and hook all your monitors to that card. Using 2 different cards is a pain in the aft.
Jul 15, 2012 | Acer ASPIRE T180-UA381B DESKTOP PC
I have a dell dimension 3000. I want to add a 2nd monitor. I believe the video is integrated, Does the unit have a slot to add a video card. What kind of card should be added?
The Dimension 3000 Springdale G chipset supports AGP 8X cards, integrated video, integrated audio, ICH5, 533/800 MHz FSB, dual channel DDR 333/400 memory, integrated Serial ATA, and the Intel Pentium 4 Prescott.
The AGP 8X slot refers to Advanced Graphics Port. You can add a AGP video card if you motherboard has that slot. Usually that slot is encased by a green plastic enclosure .
Aug 02, 2011 | Dell Dimension 3000 PC Desktop
Steady beep code
if you're using an add-on video card, check it to make sure it's functioning. make sure the video is seated properly, if it's an add-on card. if the video you're using is onboard, try an add-on video card. also check your memory. make sure it's (they're) seated properly. careful of ESD. disconnect power from computer when doing all this. reconnect power to check if what you did worked, (naturally).
Sep 24, 2009 | Foxconn 45CMX socket LGA775 motherboard...
In-built video card not working. how do i switch if off and use another video card via PCI slot?
you can disable from bios
is likely onboard vga
But if you plug in a PCI video card the computer will use that video card
Jul 09, 2009 | Intel Motherboard
There is no video on my moniter
Unplug power supply and try re-seating your memory sticks and add-in cards including video. Make sure monitor is plugged in securely to motherboard video port to start with if it has one. Sometimes you need to start up from motherboard video port first and then install your add-on video card, power off and then plug monitor in to add-on card.
Apr 10, 2009 | Computers & Internet
Unsupported video configuration detected
Do you have an add-on video card installed in your computer?
It's possible your video connection is plugged into the built in video adapter in your computer. Try having it plugged to your video card instead.
Sep 17, 2008 | Computers & Internet
Lenovo MTQ45NK Motherboard Desktop Board Thinkcentre Logo
77 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
