Question about Xerox Phaser 8860MFP Printer
Error code 39, xerox 8860 mfp
Error code 39,003.40:71001
  • 2072 Answers
SOURCE: xerox 8860 stuck in inialize
Sounds more like an NVRAM issue.
Posted on May 22, 2009
  • 141 Answers
SOURCE: LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Posted on Aug 04, 2009
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
pateltraders
  • 35 Answers
SOURCE: Tonar empty error for xerox phaser 3100 MFP pritner
easy to reset your printer counter easy to install work life time.
Rs.200 / usd: 5
Regards
Jayendra
www.chipresetters.com
msn:howtorefill@howtorefill.com
Posted on Apr 12, 2010
wrinaldo
  • 185 Answers
SOURCE: xerox phaser 8860
This unit has a common situation that requires parts and 2-3 hours of labor. This error points to a bad process motor 127K53240
These generally go bad with 2 camshafts 020K14800 and 008K02160
Whit
Item, Inc.
Posted on Aug 10, 2010
Power up a Xerox 8860 MFP printer
if the control panel display is completely blank but the printer works, you have a faulty panel. I can order it, feel free to contact me, its possible xerox will still cover this under warranty. Call xerox tech support, tell them the issue and see if the control panel would still be covered under warranty eventhough your machine is out of warranty. instructions come with replacing the part.
Mar 04, 2014 | Xerox Phaser 8860MFP Printer
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
Display shows RAM ERROR on Xerox Phaser 8860
I would first try to inspect and possibly replace the ram. On the back of the machine there are two thumb screws holding on a metal plate. Remove the two screws to access the ram. You can remove the ram and try the second ram slot if it is unused. (check the video at 2:45 to see what this looks like) If after replacing the ram and trying both ram slots the error continues you most likely need to replace the Electronics module (MFP part# 084K36560, non-mfp part# 084K36550). Here is a video that shows you how to replace that part. (video is of a 8500 non-mfp version so it is a little different but still similar). Good luck, and thanks for using FixYa!
Sep 01, 2011 | Xerox Phaser 8860MFP/D - Multifunction -...
Xerox Phaser 8860 printer is displaying 12.1 error message, what does that mean
12 codes on that machine mean a software error.
You can try removing and reseating the RAM chips , most likely its corrupted and will require a software install. The software ( Firmware) would be found at xeox.com, Click on drivers and downloads, then type in 8860 in the search box then click to drivers and downloads again and scroll down to firmware.
Jul 09, 2010 | Xerox Phaser 8860MFP Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
8860 print error 07,010.43;92622
print out comes after restarting the phaser 8860 printer and stops after sometime
Jul 04, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8860 error code 34,015.48:66749
Hi
Cyan Ink Level Sense Fault (34,015.48)
You must have a minimum of something like 3 ink blocks in each cartridge so it looks like the CYAN is running low. Double check that you have a least 3 in each one and the error should go after a reboot. Please use the link below for any further problems or let me know.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_8500_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_8500_8550):str(8860),question=ref(ProdFamily):str(Prod_8500_8550),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:8860,varset=prodName:Phaser%208860
Mar 20, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8860MFP Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
