Question about HEWLETT PACKARD - PROCURVE NTWRKNG J9020aaba procurve switch 2510-48 switches & bridges
HP procurve 2510g switch reset button is broken
How do I scan a photo from my HP2512 all-in-one
Depending on your operating system, see the following website:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=30484&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=5231933
Oct 09, 2014 | HP ProCurve Switch 2510G-24 24-Port...
Is the switch powered up ?
Faulty led of the switch generally glows when the hardware latched to it goes faulty such as fans and power supply. please check for LED in any of these. if you won.t find any LED in red in any of these then try to connect your switch through console port of the switch, if the out is coming as garbage value ie it is not asking for username and password the try to power off the switch ( your live services will go down running through that switch, so plan a MW for that) .
Aug 12, 2014 | HP ProCurve Switch 2510G-24 24-Port...
How to factory default Procurve 224M J3299A using console and/or Reset/Clear
There's a reset button on back. When pressed in a specific pattern the switch is returned to the factory default configuration. Chapter 8 discussed this in the following manual:
ftp://ftp.hp.com/pub/networking/software/59672145.pdf
May 07, 2014 | HP ProCurve 224M (J3299A) Networking...
Hp procurve 2510g-48 switch keeps freezing up after power outage
Sounds like the power outage was caused by a power surge. That could have damaged the switch, hence the reason for the freezing. I would look to getting it replaced.
Apr 30, 2014 | HP Computers & Internet
Forget password ProCurve 2312, how do i reset password
press the clear button with the end of a paper clip for two seconds. It should clear the password without erasing the configuration on the switch.
Sep 14, 2012 | HP ProCurve 2312 (J4817A#ABA) 12x10/100...
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
I want reset the factory default of my switch HP Procurve 2510G
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Mar 08, 2011 | HP ProCurve Switch 2510G-24 24-Port...
Lost enable password for 2510G
attempt to log into the system. While it's asking for the password, press the clear button on the front of the system. This will let you into the switch programming.
Dec 30, 2010 | HP ProCurve Switch 2510G-24 24-Port...
Fault led glowing on hp procurve 2650
operate a factory reset to make sure it is hardware Fault: press reset and clear simultaneously for 3 good seconds then release Clear, when Switch fault and ports start flashing let go of Reset button. If Fault Light still on, contact HP Support.
BE WARNED, this operation will remove passwords and configuration.
Aug 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
I have hp msm760 wireless controller i forgate password how can reset this
other HP ProCurve switches have a clear button on the front, I'm not sure if this one has it. At the password prompt, you can press the clear button and bypass the password.
Jul 11, 2010 | HP HEWLETT HP PROCURVE MSM760 MOBILITY...
HEWLETT PACKARD - PROCURVE NTWRKNG J9020aaba procurve switch 2510-48 switches & bridges Logo
32 people viewed this question
Top HEWLETT PACKARD - PROCURVE NTWRKNG Computers & Internet Experts
David Payne
David Payne
Are you a HEWLETT PACKARD - PROCURVE NTWRKNG Computer and Internet Expert? Answer questions, earn points and help others
