Question about Baby Gear
Bobob easy bob maxi sp - Baby Gear
What is a maxi dress?
A maxi dress is a floor or ankle length informal dress. Maxi dresses are formfitting at the top and loose flowing at the bottom, cut to flow over the body. Designer Salwar Kameez Online
Feb 18, 2013 | Clothing
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
May 26, 2012 | Maxi-Cosi Maxi Cosi Mura 3 with Free...
Does the Mico fit the easy base1?
The Maxi Cosi Mico isn't a product available in the UK so we're unable to assist with your enquiry. Please contact Maxi Cosi USA by e-mailing to crelations@djgusa.com
Mar 05, 2012 | Maxi-Cosi CabrioFix (Black Reflection)...
Lost my straps for maxi cosi cabrio carseat, can i buy new ones and install myself?
hi yes you can do it yourself easy to do if you in the uk
http://cgi.ebay.co.uk/Maxi-Cosi-Cabriofix-Car-Seat-Group-0-Harness-/120640170048?pt=UK_Baby_BabyCarSeatAccessories_SM&hash=item1c16b6e840
or contact maxi cosi direct this is for the uk
http://www.maxi-cosi.com/gb-en/contact
if you need for another country please let me know
Oct 29, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Does this model come with a maxi fuse?
Well, this bike is a bit "too new" for me but from my experiences with Harley Davidson motorcycles, they have a main breaker on most of them. A circuit breaker is a metal device that's about a half inch tall and a half inch wide by about an inch long. What it does is protect the main wiring harness. When the current draw exceeds the rating of the circuit breaker, it will heat a bi-metal strip inside the device and it will "break" the circuit. But, unlike a fuse, when it cools off, it will remake the circuit. If the over current condition still exist, it will again break the circuit. I will continue this until the condition is remedied. Unlike a fuse, you get a second chance with a circuit breaker. Once a fuse blows, it's blown and there you are unless you have a replacement. All the diagrams that I have show main circuit breakers. However, Harley may have gone to a Maxi-fuse. That would be a mistake in my opinion.
Good Luck
Steve
Jul 29, 2010 | 2006 Harley Davidson FXDBI Street Bob
When i press the switch on my harley sporster nothing happens,just blank,all lights,indicators and battery are perfect. starter switch is blank
Check your fuses especially the 40Amp maxi fuse on the l/h side of the bike under a cover below but not under the seat.
Check, clean and tighten the main ground strap from the from the battery to the frame.
Jun 03, 2009 | 2006 Harley Davidson FXDBI Street Bob
Maxi cosi car seat for a quinny buggy
Go to the Maxi Cosi website, choose your carseat model and there are Instructions online. It's a bit fiddly but once you've done it once or twice you'll find it easy.
Feb 24, 2009 | Maxi-Cosi Cabrio Red Flame Reflection...
Will Aloha Bob cables transfer to Vista Easy Transfer?
Microsoft bought Aloha Bob and shut the company, and its support sites down. Microsoft also removed all info from its website about this acquisition. The company's software was integrated into Windows Vista.
Without the ability to update the program, it is freezing. Refer to the below website for information on Aloha Bob.
Aloha Bob
Jan 04, 2009 | Eisenworld Alohabob PC Relocator Ultra...
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
