Question about Home
How to install a flapper arm assemblt to a one piece Eljer toilet
I aa trying to install a flapper arm assembly model # 495-5515-00 for a one-piece Eljer toilet and I am having a hard time installing it. First of all, there is a nut that screws onto the bottom of the assembly counter clockwise and then there is black rigid washer that I believe goes through the opening at the bottom of the tank and is sealed by the white nut. I am having a hard time bending the washer to get it through the opening at the botom of the tank. Firstly, am I doing this right and if I am how do you scrunch the washer up enough to get it through the opening?
  • 8 more comments
  • homelandfina Feb 28, 2009
    I have tried to just insert the entire assembly in the hole at the bottom of the tank without securing it and it comes out when you flush.. I am working with four parts. A bucket that the flush valve assembly with the flapper fits into. A thick rubber washer which has a lid and appears to be the part that seals at the bottom of the toilet and a thick white nut that fits through the hole at the bottom of the toilet which tightens counterclockwise I have taken these parts off of the old assembly so I know they belong with the new assembly. I have tried inserting images of all four pieces but they exceed the 150kb requirement so I can't upload them. I wish I could show the four pieces that I am working with. I need to know how to install the flapper arm assembly so as to form a perfect seal whereby water does not seep through the toilet prematurely.
    This is a one piece toilet from Eljer. Most directions cater to two piece toilets which can be taken apart and repaired.Generic diagrams do not address my specific problem. Has anyone ever encountered this situation?
    Thanks for your help Leo but that diagram only addressed TWO piece toilets mine is a one piece
    Guru
    There is no place for Phillips screws. When I took off the old assembly I had to turn the whole assembly around when it finally loosened. The thick black washer of the old flapper assembly tore. I had to special order the new assembly and unfortunately it came with no installation instructions and Plumbingsupply.com freferred me to Eljer whi in turn never returned my call.
    Ginko
    Can you describe what an OEM valve is? I tried looking it up on line and it seems to pertain to cars.
    Thanks
    neo
    Plumbing supply.com is where I bought the flapper arm assembly from and the diagram you sent me is exactly what I bought. The only problem is that there are no specific instructions on how to seat and seal that entire assembly to the bottom of the tank. Can you help?
    Peyton
    That is the problem I can't get the rigid washer through the whole. Do I need to push the washer though the hole. Is that all there is to it? and how does it tighten? the locking white nut that fits through the hole turns counterclockwise to tighten. Should this be turned to tighten while in the hole or should the assembly be pushed into place already tightened?
    Thanks
    Is there a picture of the locknut? That is the problem I do not know how to secure the assembly to the tank.
    need some more guidance more specific one piec toilets
    need more help
  • 4,369 Answers
Are you trying to install the flush valve or the flapper vavle?
What is the name of the model? Titan?
Flapper valves usually just have two holes that fit over nubs at the bottom of the fill pipe.
I would thinkt he washer sits in the bottom of the tank with the nut against it.
Posted on Feb 28, 2009
  • 1 more comment
  • gerry bissi Mar 01, 2009
    OEM means original equipment manufacture. The part is made by the same supplier that the manufactuer used to build the toilet.
    A lot of shops sell OEM Equivalant parts whixh can be made by anyone.
    It looks to me like the washer goes in from the bottom. Then the nut goes on. Don't overtighten or it will crack the plastci nut.
  • boostergold Sep 16, 2010
    or it will crack the porcelain. i ruined my
    Clawfoot Tub Shower Kit when i was installing it because i over tightened.
  • 547 Answers
Hi wel com to fixya the washer goes between tank and bowl please lift off tank and put washer on then put back. plaese rate me thank you
  • albert getty
    albert getty Feb 28, 2009
    take out part that plug sits in place washer around then put back screw in bolt attach plug set chain fill test
  • albert getty
    the wacher goes around part then part is installed
    Scholar:
  • 165 Answers
Click the link below to see the instalation procedure with pictures to guide you step by step: http://www.ehow.com/how_4728165_install-eljer-toilet.html
thanks and rate the solution accordingly.
    Sergeant:
  • 326 Answers
Http://www.wolverinebrass.com/Wolverine%20Brass/PDF/Catalog/Ballcock%20&%20Tank.pdf
click this link for both 1 piece two piece installastion step by step.
 Remove the locknut that holds the valve to the tank. Push down gently on the valve as you unscrew the nut. Pull out the old valve. Remove the cap, press down to compress the washer and screw on the locknut. Connect the supply line and flush the valve as shown in Photo 2. Reset the cap and check for leaks.
also 1 more link for mode help  http://www.rd.com/17646/article17646.html
  • 410 Answers
Have you tried soaking the seal in warm water making it pliable to see if it would go thru the hole? I looked at a diagram and i assume your not able to put the seal in from the bottom. remember when you put it back togethern the cone portion of the seal will point down towards the retaining nut. thanks Peyton
    Sniper:
  • 113 Answers
Hi there, follow the link below... i think the link information may help you.
http://www.plumbingsupply.com/eljertoiletparts-berkeley.html
Good Luck!!!
neo
  • 19,396 Answers
To fit the valve you have to push the the pvc pipe with the black gasket into the tank hole.
Ensure that you have purchased an oem valve.
This is probably not an oem valve and will not fit, go back to seller and get an oem one.
    Brigadier General:
  • 5,158 Answers
And you can't put the washer thru the top of the tank then put the assembly down thru that and secure it ?
  • Roberta Smith
    Roberta Smith Feb 28, 2009
    and if you have no choice but to put the washer in from the bottom and it is plastic... heat it up in really hot water first to make it more flexible.
  • 257 Answers
Hi, You don't have to scrunch anything. Look down in the valve seat with the flapper off and you will see two philips screws that hold in the valve assembly that allow you to remove the assembly. Then you will be able to see how the plastic nut and washer fit. Good Luck, this should Fixya!
    Scholar:
  • 85 Answers
Http://www.eljer.com/assets/documents/eljer/install/Install_2567.pdf
click the above link .in that its mentioned everything from removing the nuts screws and where they r exactly located in the unit.how to install.how to place it.also the useful diagrams are given in it with brief description.
please do rate the session accordingly.thanks.
    Brigadier General:
  • 3,614 Answers
here's the Example1 & EXAMPLE2 on your concern
  • 3,037 Answers
Hi you are over thinking this, the water seals itself in when the flapper closes, you do not need to bend the washer and may not even need to use it depending on the toilet. Extra parts are usually included in these kits as they are for multiple toilets. Take a picture and post it here of the part you are having trouble with and the area you are trying to put it and I can verify if you should need it there and are doing it right.
thanks
Benjamin
  • Benjamin Patri
    Benjamin Patri Feb 28, 2009
    you can descale the images in Paint to post them, just shrink them down until they are under the size limit.
    Ok, it sounds like you need to use sand paper or steel wool to rough up the smooth surface that the washer sits on and then get some sealant so it holds itself down. Also make
    sure the surface is clean and very dry before applying the sealant.
  • Benjamin Patri
    please just follow the above comment to seal the seal down
  • 564 Answers
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1002&Variant=Original
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
I have several eljer canterbury toilets with master fluid filler valves and the flapper seems to fluter when it fills and takes on water 2 times a night. i have tryed several types of flappers?...
Hi Guy they have a hole in the flapper with air pocket that casues them a problem, you can buy aa flapper wth a chain on it that has a float on the back of the flapper valve so you can adjust it to work right. my experince has been to put the float right up aagainst the back side of the flapper. they cost $3.99 at any hardware store.
Jun 17, 2010 | Eljer Toilet Onepiece Canterbury ...
I have one piece Eljer toilet, water tank is emptying. What do I do? It usually happens oner night.
flapper valve leaking check for build up or debris if clean check adjustment or replace flapper
Jun 10, 2010 | Eljer Toilet Onepiece Canterbury ...
How do you remove or replace the flapper.
Your leak is most likely caused by either a worn flapper or a worn valve seal. Best bet is to replace both as the coat for a new valve assembly and flapper is about $12 at Home Depot. Look for the Fluidmaster display in the plumbing department. Easy to follow instructions are included. Since you have a one-piece toilet you'll need to be sure that it will fit so measure the depth of the tank.
Jun 02, 2010 | Eljer Toilet Onepiece Canterbury ...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Always have to hold handle to get it to flush
lift the lid,and look, flush, the rubber valve that opens when lever is is pulled should float, so either its very loose or broken and needs to be replaced.plz rate-bozcro
Sep 10, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Dec 21, 2008 | Home
Home Logo
508 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
