Question about Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
Heater is stuck in standby mode
Heater stuck in standby mode
  • jcol Apr 27, 2009
    My heater is also stuck in standby mode. I found a recall notice posted on Aug. 2003 for this model (H250PED2) for a "malfunctioning circuit board". I am calling the dealer.
3 Suggested Answers
  • 990 Answers
SOURCE: Manually the heater works. However, when in
If all is in working order be sure your thermostat is turned all the way up on the heater itself and be sure your baskets are clean and your filter is clean. Also be sure that all gas valves are on and gas level in tank is above 30% and power switch on heater is turned on. I hope this helps.
Posted on Jan 27, 2010
  • 246 Answers
SOURCE: I have an H400 pool heater that is lit on standby
need a new board t get need model #
Posted on Sep 14, 2009
Just had our circuit board on H400FD Haywood pool heater replaced. Heater did fire up but wouldn't go past 65 degrees and went to standby.
It may be wired incorrectly, there are 3 terminals for the Hayward heater that connect it to automation.
1 spa
2 pool
3 comm
If they are not wired correctly this issue can happen.
Dec 31, 2016 | Pool & Spa
Richmond encore 3kw electric water heater stuck on standby mode no hot water this is a brand new unit never used!
About the only DIY repairs available are on following link:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Richmond is made by Rheem. They may tell you to call installer. Or give you name of local repair technician.
Gene
Water Heater Timers Save Money
Apr 13, 2015 | Water Water Heaters
Hayward h250
Hi this is John the Hayward tech. If you have a millivolt heater it will only have one therm and an on and off switch. What you are describing is a electronic heater. Please call our tech line at 908-355-7995
Aug 28, 2014 | Hayward H Series Millivolt 250,000 Btu...
Hayward heat display is stuck in standby
you need to replace either the display board or the main circ board
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
Machine has a error code of 77 and said to phone Brother - what does this mean?
Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the top cover is
opened and closed, or the machine exits from the sleep mode.
Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby
Apr 28, 2010 | Brother IntelliFAX 2800 Laser Fax
Jan 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
When I turn on my pool ,the heater wont turn on.
clean the filter turn breakers off for twenty secons
Sep 06, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
328 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
