Question about Premier Mounts Universal Flat Panel Wall Mount for 37"-61" Displays (Non-Tilting) - UFM
Phillips Rear Projection HDTV
I just switched from brighthouse to verizon fios digital cable. I have a black frame around the picture and verizon says that the closed captioning on the tv is set to on when it should be off. I have gone through all of the "features" options in the menu and I cannot find the closed captioning settings. All I have under features is timer, auto lock, and format. Someone please help me.
  • 92 Answers
Hi. go to the website for the company that makes the tv.
Posted on Dec 15, 2008
SOURCE:
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
07 sony 32"hdtv trouble...
sounds like you have a bad lamp maybe a bad color weel to so be careful
May 16, 2009 | Zenith D52WLCD 52" Rear Projection...
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Mitsubishi WS-65711 HDTV
The Verizon installer did not set the reciever to 1080i, had to set reciever to 1080i and then push 3 buttons in order on the reciever to take me to the nonstandard menu to check a box so that all channels without 1080 would automatically fill the screen.
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Is my tv digital compatible or not
I have a Sylvania 27 inch tv from 1986. I currently have Cable TV. Is it possible that it will not work even with a converter box?
Apr 15, 2008 | RCA P46920BL 46" Rear Projection...
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Premier Mounts Televison & Video Experts
Ekse
Are you a Premier Mounts Televison and Video Expert? Answer questions, earn points and help others
