Question about Juki MO-655 Mechanical Sewing Machine
How to adjust the stich lenght on a juki ddl 553 strite stich.
I do not know how to adjust the stich lenght on a juki ddl 553.
Thank you
I still don't understand this. I have acquiured a juki DDL 553 recently to discover I have no idea how to change the stitch length and that there is no reverse stitch. I have pressed the black button and have tried to turn the side?( the wheel?) but when i push down on the black button there is no way to turn the wheel it doesn't move, maybe there is some other part I'm supposed to be moving??
Posted on Jun 06, 2010
Press the black button while moving the side
Posted on Jan 25, 2009
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Trouble with the stiching on a juki7800
try changing the needle, make sure the needle is the correct one for the fabric being used
also adjust top thread tension
Apr 16, 2012 | Juki DDL-8700
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
Apr 19, 2011 | Juki MO-644D Mechanical Sewing Machine
I bought a used juki DDL-8500 and i am having difficulties to adjust the stiches which are being made by it. i will b grateful if u can attach a manual for the sewing together with your reply.
hi there
you can go to www.juki .com
under industerial sewing machine youy can download DDL 8700 instruction manual it's same DDL8300 model.
now you can do next steps
1- change needle with new one.
2- you can find tow mark on needle bar the upper mark for adjusting the hight of needle bar bring the needle bar at lower position and check if the upper mark aqual with the lower bushing or no.
3- when the lower mark aqual with the lower bushing at this time the blad point of hook must be at the center of groove for the needle if no lose tow screw for the hook and readjust the timming between the blad point for the hook and grove for needle bar
best regards
ashraf abozid
aabozid@hotmail.com
Aug 05, 2010 | Juki DDL-8300
Juki DDL-553 and adusting stitch length
to adjust your stitch, just move the wheel there is #. change the number.
Nov 06, 2008 | Juki MO-655 Mechanical Sewing Machine
Juki MO-655 Mechanical Sewing Machine Logo
553 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
