Question about NEC PT-390 /NITSUKO Phone
System startup in progress - NEC PT-390 /NITSUKO Phone
How do I stop backup in progress?
1.Log on to the computer by using an account that has administrator rights.
2.Click Start Collapse this imageExpand this im, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
·Collapse this imageExpand thisIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3.On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (TheUse Original Boot.ini check box is unavailable.)
4.On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
5.Click OK, and then click Restart.
Sep 03, 2015 | NTI Backup Now EZ
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
When I boot up my desktop, it will show the welcome screen then my screen will go black with a large white cursor and nothing else. From there it doesn't not progress, it just remains on that screen...
Try to re install your operating system you can't troubleshoot it if your video card is working a problem like that can be troubleshoot if you can't see any video on the screen you have said that it is working at the start up to the welcome screen so it means there's nothing wrong with your video card and monitor.
Jul 06, 2011 | Computers & Internet
New application quites upon launch on macbook OS 10.6
Welcome.
First of all, make sure that the application meets the system requirements.
Restart the computer by choosing Apple Menu - Restart. Also you can try to Restart in Safe Mode.
To Restart in Safe Mode:
  1. Shut down your computer and wait 10 seconds.
  2. Press the power button.
  3. Immediately after you hear the startup tone, hold down the Shift key.
  4. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
Hope this helps!
Dec 14, 2010 | Computers & Internet
Brand new Dell Vostro 430, in troublefree use for two weeks, sudden does not start up any more. After turning the Vostro on: - it shows the startup screen with the Dell-logo in the center, the intel...
Press DEL on startup and select "last best known config that worked" If that doesn't work you have probably corrupted the Win registry.Will need to take back to store, beware that if its a software fault you will have to pay and may lose all your data n the HDD!!!
Oct 16, 2010 | Computers & Internet
I can not get my mac beyond the starting up mode. It is running Mac OS 9.2 What to do? It has started up about 1/6th of the way. I recently was asked to upgrade. Which I did and then restarted. I...
Without knowing more about your machine, try this: after the display of the happy Mac icon, hold down the Shift-Option keys. That should start you up without any extensions. If your machine starts up with no extensions running, then there might be a corrupt extension in the batch.
A good resource for self-troubleshooting older OS' can be found here: Magical Macintosh Key Sequences. It gives you the startup key sequences to troubleshoot through startup.
Hope this helps! I'll be checking back to see on your progress!
Phil
Dec 31, 2009 | Apple Mac OS 9.2.1
Acer Veriton 7800 goes into Hibernation on startup
this sounds like your windows is not authenticated and your locked out of your pc
May 23, 2009 | E-Machines W2646 PC Desktop
Toshiba A105
i advise you to reinstall windows on a new partition
May 28, 2008 | Toshiba Satellite A105 Notebook
Startup problem
I would recommend you to boot your system and safe mode and do a system restore...To open your computer and safe mode hit the F8 button on your keyboad when the computer is booting up..click safe mode..and then once you get to safe mode its going to give you an option to restore your computer to another day..after the restore is finish, you should be able to use the computer without any problems...
Jan 31, 2008 | IBM ThinkPad G40 Notebook
Reloading windows 98 on a Panasonic Toughbook CF37
http://support.microsoft.com/kb/262381/en-us
Restart in Safe Mode and Use Msconfig.exe loadTOCNode(2, 'resolution'); Restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then choose Safe Mode from the Startup menu. For additional information about Windows 98 startup, click the article number below to view the article in the Microsoft Knowledge Base: 178548 (http://support.microsoft.com/kb/178548/EN-US/) No 'Starting Windows 98' Message at Startup After your computer restarts in Safe mode, use the System Configuration Utility tool (Msconfig.exe) to minimize conflicts that may prevent your computer from finishing Setup.
To start and use the System Information tool: 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Information. 2. On the Tools menu, click System Configuration Utility. 3. On the General tab, click Selective Startup, and then click to clear the following check boxes: • Process Config.sys FileProcess Autoexec.bat FileProcess Winstart.bat File (if available) • Process System.ini FileProcess Win.ini FileLoad Startup Group Items
Dec 05, 2007 | Computers & Internet
Lands Phones Logo
52 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
