Question about Microwave Ovens
I need a parts diagram/manual for a kenmore microwave 665.69612992
What does F44 error code on Kenmore Elite model 790.4890 mean?
You may be missing a digit in the model number. I believe that this microwave was built by Electrolux for the Kenmore line. The F44 error indicates that the external cooling fan for the microwave is spinning too fast. This can be caused by a blockage. Check if there is anything blocking the airflow. Make sure that the voltage coming into the microwave is correct. If your voltage is too high, then the fan will spin faster.
The fan is part 108 on this diagram: http://www.searspartsdirect.com/model-part/79048903000/0583/0125400/r1009032/00003.html . It's at the back of the deflector at the top of the microwave. This is the diagram for the 790.48903000 .
If there is nothing wrong with the fan (spinning normally), then the problem is between the fan speed sensor and the control board. This should be fixed by a professional.
I hope this helps.
Jul 15, 2016 | Kenmore Microwave Ovens
Sears l kenmore microwave 665.60622000
Most Kenmore appliance manuals are available from Manage My Life. For the 665.60622000 microwave and range hood User's Guide, see http://www.managemylife.com/mmh/owner_manuals/5728/KENMORE-Microwave-Hood-Combo-L0211211?brand_name_search=665.60622000 . This will load the PDF in the browser window if you have a PDF reader plugin. If you wish to download the manual, the direct link is http://www.managemylife.com/mmh/lis_pdf/OWNM/L0211211.pdf . You need Adobe Reader or a similar program to read the file. If you want only the Installation guide, start here: http://www.managemylife.com/mmh/owner_manuals/search?query=665.60622000 . Unfortunately, you will need to print your own copy from the PDF. (Alternatively, go to a print shop with the file on a flash drive and they will print the file for a fee.) Sears no longer has the manuals available for sale at Sears Parts Direct, http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-66560622000/0582/0123370/P0080166/00001?blt=06&prst=&shdMod= .
I hope this helps.
Jul 18, 2013 | Microwave Ovens
Need owner's manual for Sears analog multimeter
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears Parts Directimage-4235112-10659157 site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer. # # #
Dec 12, 2012 | Microwave Ovens
I just bought an 1100 watt microwave oven from K-mart and when I opened th box there was no manual in the box. The microwave number is 66222. how can I get a manual
Many Kenmore appliance manuals are available from Manage My Life. com . The Kenmore 66222 manual is here: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . A printed copy is available from Sears Parts Direct: http://www.managemylife.com/mmh/owner_manuals/23454/KENMORE-Countertop-Microwave-L0520944?brand_name_search=Kenmore+66222 . Scroll down for the manual; it's the fourth from the bottom.
Unless the microwave was labeled as a refurbished or open box unit, I'd contact K-mart customer service and see if they'll send you a replacement manual before you order one.
I hope this helps.
Jul 15, 2011 | Kenmore 66222 Microwave Oven
I need to replace light on kenmore microwave oven model 721.66312
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
May 10, 2009 | Microwave Ovens
Need to replace light inside kenmore microwave
Unplug the unit first.
To install the halogen lamp WB08X10050 you will need to take the cover off. You can see a diagram at;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=36363693302&productCategoryId=0123370&brandId=0583&modelName=MICROWAVE&diagramPageId=00006&componentDescription=INTERIOR%20PARTS%20(2)&documentId=S9060341&backToLink=Return%20to%20Sub%20Components%20list
then click on "view full size"
This will give a view of the parts. Only remove the parts needed to get to the bulb.
Mar 26, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave Not heating Foodas quick
You can find parts lists and diagrams on this Sears Web Page. There is a good possibility that your magnetron tube is getting weak. Make sure the interior is clean and doesn't have any rust or holes in it. Also check the seal around the door for corrosion. If you're not familiar with electrical and electronic repair work, you may need to take it to an experienced microwave service technician to get an accurate diagnosis of all the needed parts.
Jan 16, 2008 | Microwave Ovens
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
