Question about Measuring Tools & Sensors
How to reset my Acurite 1099rx after replacing battery
After replacing battery's on my 1099RX Acurite outside unit temperature only blinks and unable to locate reset button?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
Posted on Mar 21, 2016
2 Suggested Answers
SOURCE: I have the Acurite 00604RX
how do i set my clock for accurite 00604RX
Posted on Sep 07, 2011
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Model 1099rx not working,even after I replaced all batteries
sorry but we need make and model to begin the process .
Mar 31, 2015 | Computers & Internet
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
I have model 00606TX. I had to replace the batteries on both components but cannot get the outside temperature to register on the display. I checked that the batteries were installed correctly and t
Hi Stephanie!
We would need the model number of the main display unit to give full instructions or you can visit; http://www.acurite.com/kbase
and enter that model number for troubleshooting tips and steps.
Nov 22, 2014 | Measuring Tools & Sensors
Why is the outside temperature not displaying on the base?
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Jan 24, 2013 | AcuRite Acu-Rite 00593W Wireless Weather...
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
Outdoor device won't register inside.
All these wireless weather station devices have to be paired to the base unit whenever the batteries are changed in any of the remotes. It's a poor design issue, but there is no way around it, due to the nature of wireless operation.
Place both units near each other and look on the back of your base and remote sensor units, you should find a reset button (or a small hole). Either press the button or use the end of a paper clip to depress and hold the reset on each unit; Base 1st, then the remote 2nd.
After a brief moment, the remote should register with the base and you'll be back getting wireless readings.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Kitchen Appliances - Others
Measuring Tools & Sensors Logo
2,236 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
