Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Panel out Front panel out no water no ice dispencing no lights however refigerator and freezer working.
  • Anonymous Mar 30, 2014
    button does not work
    Novelist:
  • 159 Answers
Replace the control bord if there is no function.
Posted on Jul 13, 2007
SOURCE:
Freezer doesn't make ice but water still works on front dispencer
HI,
I looked up your unit and the only problem I can see would be the full tube to the ice maker could be clogged with Ice not allow water to enter the ice maker, or a bad water valve which is located behind the unit on the back right side (freezer bottom). I would look at the fill tube start as this was more common.
I hope this helps
Water valve part number is you need is 4389177
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 23, 2011 | KitchenAid KSRA25ILSS Side by Side...
Light in freezer side will not work also will not dispence ice
if it is a fuse / the fuse is located inthe wire harness on the side of ice maker . it is in a clip and looks like black plastic . four wires oly the one in clis is fused. mm
Jul 16, 2010 | Kenmore Refrigerators
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 22, 2010 | Refrigerators
My control panel on the freezer door stopped working all together. Everything else on the fridge is working fine just the panel for the ice and water dispencer and all the lights on the panel. Thanks Eric
Make sure the wires on the left top door hinge are still connected. They are usually under a plastic hinge cover.
Sometimes there are wires on the bottom left door hinge that get disconnected when you move the fridge as well.
Mar 11, 2010 | Refrigerators
The refigerator does not get cold. Long term ice forms in Freezer blocking through holes. When first pugged in seems to circulate air to refrigerator
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Refrigerators
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Mar 21, 2009 | Samsung RS2534 Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
