Question about Acer Aspire 5670 Notebook
System Errors - WiFi connectivity
I am currently having issues with my Wireless 802.11 a/b/g device on my Aspire 5670.
I usually leave my laptop on with internet connectivity. On Wednesday evening, I went to shut the computer off but I got an error stating: Unable to disable the Wireless Adapter.
I had been having a few issues with connecting to the internet and playing on-line games since Monday, but the device reported being enabled and in working order.
I finally had to reset the computer to get it to shut off. When it restarted, the Windows Bluescreen prompt came up stating "Windows wasn't shut down correctly and needed to check the system: Press any key to skip" - when I went to push a key, I found my keyboard was disabled and I couldn't skip the check even if I wanted to.
When Windows did finally load, it took 10 minutes to get from the log on screen to a functional desktop, but I found my wireless adapter was disabled. I couldn't get it to come on and any of my mouse commands took 2-3 minutes to process.
I then restarted my computer in Windows Safe Mode with networking. This start-up took the usual amount of time, but I found again my wireless adapter was still disabled and I could not get it to come back on via system network control or by pushing the button on the front of the computer.
Everytime I have restarted my computer not through safe mode, Windows always states it needs to run system check and my keyboard is disabled, not allowing me to skip the process. It always finds a different file being "too big" and says it's fixed, but as soon as the log in screen comes up, it takes at least 10 min to load and then is not fully functional.
I did finally get my wireless adapter to come on, but I had to go through networking advanced settings and actually turn it on, and then push the button to get the adapter to activate - BUT Windows and the System Hardware Device Manager has said the adapter was working the entire time.
So . . . Basically my laptop is not able to be utilized unless I'm running under safe mode and that kind of defeats the purpose of using a blazing fast laptop (which has been perfect up to this point) for gaming and applications when it now runs like a car on four flat tires.
Please advise...
  • 520 Answers
Lots of choices...
if you have os disk boot off it and select repair which will take you to the dos prompt..(c://)
here type chkdsk and enter this will check and fix any errors.
other choice....when you start pc and get to login window select logout,wait for next page (a few seconds) and select login and it should load a lot quicker if this sorts it let me know and I'll tell you why this is and what to do unless your happy doing that each time.
the wifi...
once windows and drivers all loaded open control panel,select administrative tools select services and scroll to wireless zero config and press start.this will solve 2 issues.first it will get u connected 2nd it will verify that your wifi manager (software addon with drivers)is incompatable or not installed correctly or has conflicts either way youll need to uninstall it and reinstall or leave pc set for windows config
Posted on Jan 24, 2009
Network Adapter will not work on Startup
Attach a Ethernet cable to the laptop, Open Device Manager, Network Adapters, Uninstall the Wireless adapter, reboot, Allow the software to apply the generic driver, try to connect to wireless network. Post results.
Jan 26, 2013 | Acer Aspire Computers & Internet
My acer aspire wont connect to my centurylink wifi
Try re-installing the wireless card driver and the configure the wireless card to the wireless router's wireless settings. You can also have a look at the wireless card settings in the computers that is connecting to the wireless router/Internet and then apply these settings to the wireless card in the Acer.
Nov 08, 2012 | Acer Aspire 5253-bz692
How to connect the wifi to a acer aspire 5733z - 4851 laptop
Check the wireless router and high-speed modem. If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
  • 2 Activate the wireless Internet connection on the laptop computer. Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu. Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
  • 3 Select the appropriate network you wish to connect to. Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
  • 4 Restart the computer. The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
  • Oct 09, 2011 | Computers & Internet
    My laptop (acer aspire 4930) wifi is not able to detect wireless networks. It has been working fine for 1.5 years but something has happened today that it is not able to detect the wireless connections.
    Double check that the Wi-Fi didn't accidentally get turned off. There should be a button on your computer that turns it on and off or a fn key usually fn+f2. Try that first if that doesn't solve the issue try reinstalling your driver which can be found at the following site.
    http://support.acer-euro.com/drivers/notebook/as_4930.html
    Apr 19, 2011 | Acer Aspire 4930-6862 Laptop
    Aspire 5670 wifi issues. I am showing that I am connected to the internet but unable to connect to net request is timed out. ipconfig shows address. ping yahoo .com request timed out.
    Bring up the browser window, don't worry that you can't connect. If it is IE, look to the right upper and choose the drop down menu "Tools". Scroll down and choose "Internet Options", Click on the "Connections" tab. Scroll down the bottom half and click on LAN settings. Make sure that everything on this page is unchecked. If there are checks present, clear them, hit apply and ok.
    If there were no checks anywhere, then you may have to go the "device Manager", scroll down to the network devices and uninstall them one at a time and reboot, thus allowing Windows to recognize them and load a fresh driver.
    Sep 18, 2010 | Acer Aspire 5670 Notebook
    How do i turn on wireless on acer aspire 4810tz
    It has a touch panel at the top above the keyboard touch it to turn on also go into the control panel and select wireless devices select wireless you see a wire connection and a wireless connection right click on it select properties and you will see an option to enable or disable enable it an it should come on
    Feb 02, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
    Acer aspire one having issues contecting to my
    make sure you're plugged in....
    Right Click THe Wifi Icon by your clock and choose to repair connection
    if still not connecting.... uninstall wifi from the device manager and reboot
    Dec 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
    I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
    Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
    Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
    Try searching for this other network. Your router documentation should advise you of its default name & any set up process
    Dec 23, 2009 | Acer Computers & Internet
    Aspire web connections
    To go wireless:
    1.- check if your wireless device is working
    2.- If not you have to turn it on
    3.- Select your wireless network (control panel>>network connections>>wireless networks)
    4.- Connect to the network (is the network is pass protected you will prompt for a password)
    If above doesn't help, please describe better your issue
    Sep 25, 2008 | Acer Aspire 1360 Notebook
    Wireless adapter
    You can use a USB wireless adapter.
    Mar 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Acer Aspire 5670 Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
