Question about Kenmore 2303x Top Load Washer
Kenmore elite washing machine model 11023032100 troubleshooting guide
Water leak and how to remove the back of washer
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Washing Machine leaking water
Okay...my experience with this model front loader leads to the following possible problems:
CAUTION: UNPLUG the washer if you plan to service the interior. It is dangerous to have your hands inside the unit with moving parts and energized. Plug the washer back in and stand back if you plan on doing any operation checks.
1. Door bellow ripped or torn (this is the gray rubber boot around the door - open the door and inspect along the entire door boot. Including the areas behind the rubber fold where the rubber meets the wash tub. It is common for them wear out and tear. NOTE: Make sure the fill hose on the left-hand side of the door boot is fully snug in place. Sometimes it will come loose and leak BEHIND the door boot.
2. Drain pump or hoses leaking - You will need to remove the lower panel under the door to see inside the washer. Remove the three torx type screws under the front lip at the bottom of the panel. For easier access, place a small block of wood under each front foot. The washer is heavy so you may need assistance to lift the front slightly. CAUTION: Do not lift on the door, push on the door panel or control panel. If the panel sticks, slightly tap on the sides and it will drop down and come off. The pump is located in the front under the wash tub. Make sure the clean out trap is snug and all your hoses are tight and not torn. Check the drain hose that leads out of the back of the washer from the drain pump to ensure it is not cracked.
3. Air Dome hose has come loose from the tub - This will be a small rubber hose connected to a plastic piece (called an air dome) on the right-hand side of the wash tub as you are looking in from where you removed the bottom panel. It should be located behind the drain pump and mounted physically to the wash tub. The other end of this hose runs to the pressure switch, which turns the water flow off when the washer tub fills to the approriate level. If this hose comes off, the washer will start to leak on the FILL cycle and will not shut off. I don't think this is what you are talking about, but it is still worth a look since you have the panel opened.
4. Tub seal leaking or tub cracked - These would be the most undesirable of all possible problems because it would require the removal of the entire wash tub in order to correct. Inspect the wash tub seam and make sure there's no water coming from around the tub.
I hope this gives you a few possible items to work with. Inpsect the washer interior when you get the panel off and post back if you can determine where the leak is coming from.
HELPFUL HINT: Put the washer into diagnostics mode if you plan to leak test. At the control panel select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, however). "C00" will be displayed on the operator console, and you will hear the door latch engage. The washer will run through a series of tests by filling using hot and cold water, checks all your dispenser features, tumbles the drum, spins and drains. This diagnostics can be stopped at any time by pressing the PAUSE/CANCEL button twice. The drain pump will come on and drain the washer.
I hope this helps you...
Posted on Feb 20, 2008
  • 156 Answers
SOURCE: kenmore elite calyspo washing machine model #110.2206
that washer the noise you are saying i have found maney things the most common one being the break and basket drive
Posted on Feb 25, 2008
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
We purchases a uses kenmore elite washing machine. When we hooked it up, and put the first load in and turned it on, water sprayed inside and leaked. We imediately unplugged the machine. Now we can
use a t-20 torx or a 7 mm socket to remove the toe kick under the door. then on the right side under the door, reach up inside the front panel find the door lock. at the bottom of the door lock you will feel a flat circular tab. pull the tab about a half inch and PULL ON THE DOOR AT THE SAME TIME.. then start washer and see if you can determine where water is leaking. if you can replace a simple part and repair it, use your model# and do a google search for parts.
May 13, 2012 | Kenmore Elite 45986 Front Load Washer
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Aug 29, 2008 | Kenmore 22062 Top Load Washer
Kenmore 2303x Top Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
