Question about Dryers
695075 WHIRLPOOL DRYER wiring diagram centrifuge
protek480
  • 1723 Answers
SOURCE: I cant find the right conections diagram for the
The dryer has a diagram on the machine. The centrifugal switch is on the end of the motor and they close when the motor is running. This contact is in the element circuit.
Posted on Jul 11, 2009
hiltonjug
  • 612 Answers
SOURCE: wire diagram 4 whirlpool dryer wed8300swo
I can't find a diagram but I can tell you. The two out side are your hot and the center is nutral. If you are putting a four wire on, it just adds a ground to the three.
Please rate solution
Posted on Sep 07, 2009
  • 949 Answers
SOURCE: Whirlpool Gas Dryer
Here is a link to your diagram, Whirlpool prints both gas and electric models on the same page, since yours is gas use the bottom diagram.
Let me know if you have questions.
Tech_Sheet_01_20_2010/Wiring%20Sheet%20-%20W10185979.pdf
Posted on May 05, 2010
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Fix-Fox
  • 7 Answers
Here you go again :-)
Wiring diagram whirlpool dryer wed4800
We are unable to porvide wiring diagrams for your Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 02, 2017 | Whirlpool Dryers
8 year old dryer. drum not spinning to tumble the clothes. checked and the belt is ok? What is the next thing to troubleshoot?
Check that the motor is turning. If not turning, is it humming? If humming, then the problem is likely start winding or centrifugal switch failure. Try lubricating centrifugal switch if stuck. If that does not work, replace motor. Be sure to disconnect dryer before working on it. Centrifugal switch assembly is located in the motor frame on the shaft.
Nov 28, 2010 | Whirlpool Dryers
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
My whirlpool dryer start when you press the start button - but as soon as you stop pussing the start button the machine stop and does not continue on it self.
This problem is most commonly due to the motor. The motor has an internal switch called a centrifugal switch that senses when the motor is up to speed.
The second cause could be the start relay (this is present on some but not all models), this is part of the start button you push and is less expensive than the motor, it can be checked with an ohm meter to determine which component is faulty.
If you can send me your model number I can pull up the wiring diagram to determine which type of start component is on your Whirlpool. The model number can be found on the tag just inside the door
Jul 28, 2010 | Dryers
Whirlpool Gas Dryer I need the wiring diagram of Whirlpool WGD 5000
May 05, 2010 | Whirlpool Dryers
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    I cant find the right conections diagram for the three wires from the motor to the centrifugal switch on a Maytag DG 590 Dryer can some one help me to find out this?
    Jul 11, 2009 | Dryers
    Wire diagram 4 whirlpool dryer wed8300swo
    Apr 26, 2009 | Whirlpool WED8300S Dryer
    Starts with asistance then shuts off.
    A centrifugal switch selects the start winding, but the run winding is always selected, according to the wiring diagram.
    So, it could be a bad centrifugal switch, or a bad motor. You can test the motor by measuring the resistance between the blue and white-orange wires (the run winding), and between the blue and violet wire (the start winding). Both values should be under 4 ohms.
    To continue running, the motor run winding must be OK, the door switch must be closed, the belt switch must be closed, and the thermal fuse must be OK.
    All this assumes the electronic controller is OK, but this is the stuff a handy homeowner can check before calling in the big Sears guns.
    Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
    Dryers Logo
    Top Dryers Experts
