Question about Protron PLTV3250 32 in. LCD Television
Protron pltv3250 32 in. lcd, no power, no lights
The outlet is good, i have power there, last night the tv worked today nothing manual or remote wont turn the tv on.
  • 12 more comments
  • dupesmiley Jan 27, 2009
    I have the same problem, no power. The previous day the battery remote low came on over the TV ( I have DISH satellite). I continued to watch 'tv through out the day. I turned the set off when I was retiring for the nIght. I tried to turn the set on the next morning and I could not get the power to turn on remotely or mannually. I disconected everything and started fresh. I even tried a power cord from the same version TV of my roomate to no avail. Can anyone tell me the cost of replacing the powersupply? Is it worth the cost?
  • ptriggs Jan 27, 2009
    I also have the same problem. I checked the plug, looks fine. It will not turn on manually, or with the remote. Was working fine when I left for the store, not working an hour later.
  • Anonymous Feb 04, 2009
    proton pltv3250 will not turn on manually or by remote
  • Jackiealtman Mar 09, 2009
    TV just stopped working. Checked power outlets, everything is okay. TV is not getting power for some reason.
  • Kathy Tracy Mar 15, 2009
    wont go on manuelly or anyway!!!!!!! did you get yours fixed???
  • Anonymous Mar 28, 2009
    Cable jack got bent, worked until next morning, then nothing.
  • Anonymous Apr 13, 2009
    i was watching tv, everything was just fine, i shut it off, and the next time i tried to turn it on , there just wasnt any power. i tried plugging it in somewhere else, i tried manually turning it on. i have had it stored in my spare room for 2 years still in the box, i have been using it for less than a year.
    i have a 32\liquidcrystal pltv \3250 doing the same thing tv willnot come on at all . i replaced the fuse and cord . will not work
  • mdsundbom May 02, 2009
    Mine died in the middle of watching a DVD. I took a look at the internal power supply and checked the fuse. It was good. I did notice quite a bit of discoloration due to heat on the main circuit board around one of the components. I am looking for a replacement power supply but after reading some of the posts here I wonder if it is worth the trouble and cost. Especially since the remote died sometime ago as well.
  • Becky Gamenotes
    Becky Gamenotes May 04, 2009
    Our Protron PLTV-3250 stopped working Jan. 2009 at less than 60 weeks old. This TV is STILL under warranty and these people refuse to do anything whatsoever, including replying to my email or phone calls!
    We added a 2-yr Warranty to the 1-yr. Warranty. That may equal 3-years but it isn't worth anything. Many times I've contacted Protron and RepairTech - and nothing - nada - ripoff - THEY ARE CROOKS - as far as we're concerned. We cannot believe that they're still selling their products!
    I've got the documents to back up everything. You can contact me here :http://www.xinbox.com/clifnotes
  • Anonymous May 09, 2009
    I have the same problem watched tv just fine last night got up this morning turned the tv on worked for a little bit and then the picture went out and all I had was sound then I turn the tv off and now it wont turn on at all
  • wasntme01 May 10, 2009
    My Protron 32" went out a year and a half ago. As a matter of fact, it went out while I was still paying for it (credit card). It's the biggest piece of **** TV I have ever owned. As a matter of fact, I went back to the regular tube tv because it doesn't break! I should have known better than to buy from an unknown company who ends up filing for bankruptcy and leaving us all high and dry...with broken TV's. Mine has no picture and no sound. The power button lights up red when plugged in, then when you press power it turns green and you still get NOTHING! When you then try to press power to turn it off, the light stays green. I bought it from Sears and they were of no help. I got it as a christmas present. It wasn't a gift that kept on giving. What a disappointment. I figured I'd check the boards every now and then and seen if anyone found a "cure" to the problem.
  • cjingra May 15, 2009
    While watching the TV it shut off and has not come back on. Have tried different outlets and just removing and replacing the power supply. TV is about 2 1/2 years old. By the posts here I guess it is not worth trying to get Protron on the phone. I called a local repair service and they said they have fixed other Protron TV's with same problem between $40-$60. Said it is usually the internal power supply.
  • Anonymous May 16, 2009
    Same thing here. One of the components on the Power supply board burned out. Taking a closer look at it I realized it heated up so much it damaged the circuit board. Not sure if I can just replace the burned out piece or have to replace the entire board. Cheapest one on line I have found is around $100. Not sure if it is worth it.
    Problem Solver:
  • 5 Answers
You will have to have the set checked by someone to confirm this,
but most likely there is a problem with the TVs internal power supply.
Posted on Jan 25, 2009
CAN ANYONE TELL ME THE VALUE OF Q7 AND C02 ON A PROTRON LPTV3250 LCD TV , ??????? THANK YOU!!!!
Posted on Jun 29, 2009
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Thunder storm last night
have u made sure that the out let has power yet? if not check fuse box.
next, if has power to outlet, manually press power button not remote controll, after it has been unplugged for some time. view the back pannel of tv. and see if there is a fuse or fuse notification. follow manufactuar or owners manual instructions from here, google vizio support or call 888 849 4623 with model and info ready
Jul 13, 2012 | Vizio VW32L 32 in. LCD HDTV
Tv wont turn on
outlet power and fuse check them . don't forget that if you want to replce fuse , you have to replace with a fuse with same rating
Sep 15, 2009 | Protron PLTV3250 32 in. LCD Television
Protron PLTV-26 gets power but nothing else. No
i have a protron lcd menu light keeps flashing but tv wont come on any help would be appreciated.
Sep 06, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron lcd tv getting no power
Replace the power supply inside the tv. I have found ther here. They are the cheepest place that has them.$60 not $100 at shop jimmy.
http://www.power-on.com/lcd194-3f.html
May 26, 2009 | Protron PLTV-32 Television
Do i need a remote to operate tv
once you have front panel in the tv and this one shows power channel +- volumen +- menu then your tv has to work with those ones and the remote is a second option to do the same. With this i mean you tv has to respond and at least show menu when you push that button " if no signal (cable DVD VCR) plug in"
Then if the tv is dead you should try to repair or sent it to repair. and then get the remote control and it can be universal too.
May 01, 2009 | Protron PLTV3250 32 in. LCD Television
No picture/sound
power supply going bad. or went bad.
get one here. The have the best price.$60
and not $100-150.
Mar 17, 2009 | Protron PLTV-4250 42 in. LCD Television
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Mar 31, 2008 | Protron PLTV-37 37 in. LCD Television
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
Protron PLTV3250 32 in. LCD Television Logo
1,092 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
