Question about Pelonis Heating & Cooling
Pelonis heater only blows cold air now
Model# hf-0020t
MNfisherman
  • 11896 Answers
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
Posted on May 15, 2009
  • 4 Answers
SOURCE: Pelonis HF-0034 turned off 10 sec after starting; won't restart
I've been through 4 or 5 of these (and similar models) with the same problem after anywhere from 3 months to 1 year of use. It appears to be an overheat condition. Unplugging for about 10 minutes resets the overheat protector, but it will overheat again after running a short time.
Sometimes you can extend the life by blowing out the heater with compressed air, especially around the electronics at the very top and the contact points at the top of the circular heating element.
I'm currently trying a Lasko 755320 from amazon.com -- cheaper, more features, better user interface, more heat, and it almost has to be more reliable than the pelonis.
Posted on Nov 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 01, 2009
  • 185 Answers
SOURCE: DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: reddy heater blows cold air
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
I need to see how the fan goes together on model number HF 0020T
something get sucked into it ??
pulls apart from the back
screws may be tamper proof- torx or star
Nov 23, 2016 | Dryers
How do i get my pelonis electric heater to work right?
sometimes it helps to blow thru them with compressed air backward. some dirt gets past filters
Jan 07, 2015 | Pelonis Heating & Cooling
HF-0020T Fan Forced heater
If the symptoms are as described, the heater probably has failed completely.
Nov 01, 2012 | Pelonis Heating & Cooling
Need switch gzs-15-2 can not find retailer
I am also trying to find this switch. It is for an oil filled space heater.
It seems that those of us in the USA that CAN fix things have to suffer from lack of parts because many here just throw stuff away and buy new.These are the same ignorant gas bags that love to talk about recycling but throw their "broken" stuff away.
As for GZS-15 rotating switch, I can only find mention of it on Chinese sites. Even after translating, I find no mention of sale.
Also, fixya is a POS site and I hate seeing so many results of it on search engines.
Sep 25, 2010 | Heating & Cooling
Only warm air
If its' tank is full of water then empty it. If it is not full of water then the switch underneath the tank may be faulty
Apr 19, 2010 | Pelonis KCD-25YI Air Conditioner
Dec 26, 2008 | Pelonis HF-0019 OSCILLATING HEATER - OFF...
Hf-0022
tap the heater gently. i say GENTLY, in the area of the on switch. try this several times. usually the tip over mechanism will stick. i say gently.
Nov 21, 2007 | Pelonis HB156T Ceramic Compact Heater
Heating & Cooling Logo
125 people viewed this question
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
