Question about Sony Playstation 3 (PS3) Console
Playstation 3 at power on, light becomes white then blinks red
While playing, PS3 shut down by itself. Trying to power on after, power light becomes white for a second then starts to blink red.It continues to blink until I touch the power button then stays red, no blinking. When I try to power on again, same patern again.
Thank you for your support.
  • 2 more comments
  • Anonymous Jan 25, 2009
    i have the same problem
  • Anonymous Feb 08, 2009
    When I touch to turn on, it too turns white etc.
  • Anonymous Mar 14, 2014
    my ps3 blinks red and when i turn it on it just shuts off again. why?
  • Anonymous Mar 20, 2014
    It turns on for a couple of seconds then shuts off with the red light blinking.
    President:
  • 2,653 Answers
Probably and overheating problem. Here's what I suggest:
Try using some compressed air and cleaning the vents out below. If that doesn't work then you'll have to remove and replace the thermal compound on the GPU and CPU.
You might also consider a System Restore if you can do it before it shuts off.
Posted on Feb 21, 2009
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Jun 07, 2012 | Sony Playstation 3 (PS3) Console
The playstation 3 shut off in the middle of play. Now the little red light just keeps blinking. We unplugged it made sure theere was nothing blocking it to cause it to over heat, we plugged it back in and...
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...... u just fix this by using ps3 repair guide....
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
My playstation just shut off an the red light flashes
do you get a yellow light? i bet you do..
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
I was playing online when the console shut down and the light on the front started blinking red. when i try to turn the console on the green light comes on and then turns yellow and then goes back to...
This could be any of a number of problems try these solutions one of which may work. If they all fail to work you can contact sony directly at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
  • Remove any obstructions from the vents.
  • Allow at least 4 inches of clearance on all sides for the PLAYSTATION 3.
  • Remove the PLAYSTATION 3 from any cabinets so it is out in the open.
  • Shut the PLAYSTATION 3 down completely and let it cool down to room temperature, then try running it again.
  • If the fan cannot be heard before the system shut down, the PLAYSTATION 3 may need to be sent in for service.
  • If there is no airflow from any of the vents, the system may need to be sent in for service
Hope this helps. Also be sure to rate whether this helped or not.
Jun 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 switching itself off
Let me guess...
You get a blinking red light then it shuts off.
Your system probably overheated and unfortunately Sony has it setup so that when it happens you have to send it in for service.
Are you still under warranty?
Jun 19, 2009 | Sony Playstation 3 (PS3) Console
Red light green light yellowlight red blinking light
From what I understand its a problem with the backwards compatibililty(the engine/drive that lets you play ps1/ps2 games)on the 60g.Sony says they have never heard of this problem yet these models are no longer in production.I have had mine for 2 years and it died today,same problem.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
PS3 has overheated, and caused the solder under the cell processor to get that hot it's melted.
When they've dried / set they have had either cracks appear or they have become warped.
The only solution is to reflow / resolder these joints.
We offer a well priced repair service, and also a longer warranty than most.
FixMyConsole
Power light blinking red not playing or edjecting
There are a few small things you can try.
Check out my guide here:
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Won't turn on blinking light
Are you trying to turn the PS3 on via bluetooth controller? If so, attempted to turn PS3 on from console itself. Sometimes the controller will get out of sync with the system and not allow for turning on remotely.
Sep 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
424 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
