I HAVE SANYO WASHING MACHIN AWD-A845ZT .SHOW IN DISPLAY ERROR (U2) PLEASE HELP ME
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
What is the cause for this error code EH1 on AWD-703HCTP Sanyo washing machine?
A possible answer is that the machine runs for a short while and then stops. So check water supply filter is not blocked, pipe kinked, outflow pump clear and that the filter is clear.
THE biggest cause for any machine not to work is actually the pump out pump and filter are jammed probably thru stuff not removed from clothing, coins (will nicely smash holes in machine) paper and fluff. Also check for overloading, frankly most people overload machines. Just a thought, nobody has turned the water off!
Your error codes may be on the machine or service booklet. The above are the most frequent generic problems.
Nov 25, 2014 | Washing Machines
Sanyo washing machine AWD-703HCTP DISPLAYED EH1 ERROR CODE what is the problem
Maybe you have solved your problem, but if not, I haven't much good news, just a website with more info about Sanyo washing machines. That division of the giant Sanyo was sold to Panasonic.
The link for more about the washers is...
http://ashachine.info/sanyo-washing-machine/
Good luck.
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
My sharp ar150n shows u2 error code and wont work please help
U2 is a problem in the laser unit, if after resetting it is still showing then you need to get it replaced.
Nov 30, 2009 | Sharp Office Equipment & Supplies
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
My photocopy machine, any message....call for service...U2-40
hi elisabeth,
unfortunately i don't have the manual for this machine but on others it's a communication problem with the chip on the toner cartridge.
if you use aftermarket/refilled toner you might have gotten a bad one.
did this error show up right after you changed toner?
Jan 26, 2009 | Office Equipment & Supplies
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
