Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice Dispenser on GE Profile PSS23MSTC does not work.
You hear a pop sound when you push the bottom to dispense the ice,
but no ice comes out. Occasionally it will work for a second, then a it continues with a 'pop' and nothing.
  • clermontd Jan 24, 2009
    No water either. THe motor may run if you try it every 4 or 5 days, just for a few seconds. Then it quits.
  • Anonymous Jan 26, 2009
    Ice dispensing from the door is intermitent. I notice that if no other components (fans, compressor do not seem to be running because it is silent) it works fine. Seems to always dim the lights when I try and it doesn't work.
    Sniper:
  • 50 Answers
Sounds like the ice is stuck together and the auger can't turn. remove ice tray and dump old ice new cubes should begin falling into tray after 30 minutes or so.
Posted on Jan 24, 2009
Water Dispenser on GE Profile Bottom Freezer Refrigerator Not Working
When you press the water dispenser button, do you hear a noise like water is trying to come as usual. If so then your problem might be frozen chill water tank or failed chill water valve. If you don't hear the regular noise then the problem might be with the dispenser unit.
Nov 26, 2013 | Star Manufacturing GE Profile PFSS5NJX...
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser has rust
The rust will conterminate your ice, please have the spiral ice dispenser replaced.
Jul 30, 2009 | GE Profile Performance 25.2 cu. ft....
Ice maker works, water will not dispense
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Jul 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser not working
your welcome sorry i wasnt able to save you a service call
Mar 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Jan 25, 2008 | Refrigerators
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
167 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
