Question about GE Refrigerators
Frigidaire model lftr1814lw6 runs but no cool
Problem: Frigidaire Model LFTR1814LW6 Refrigerator. freezer does not cool properly. How do I Correct this?
check the tempeture control thermostat and the thermistors check door seals and damper vents as well
Feb 20, 2015 | Frigidaire Refrigerators
My side-by-side model is frs26zgg,please help to know why freezer is not cool?
Hello friend, thank you for your inquiry!
From my understanding your Frigidaire refrigerator is running but not cooling. I would perform a reset on your appliance which can be done by disconnecting power from your refrigerator for roughly ten minutes. Hopefully that helps. -Matt
Sep 19, 2014 | Frigidaire Refrigerators
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Lftr1814lw6 ba21041651 won't cool box?
you either have a bad defrost timer,,not likely
a bad thermstat most likely
or a bad heating element middle likely of the three
Jul 06, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator wont cool or freeze
Hi Teddy,
It's my understanding that your Frigidaire refrigerator, model# MRS20WRGW2, has power with the lights coming on, it's just not cooling in the freezer or refrigerator portion. Since you are receiving power to the appliance, I would check to see if you can hear the compressor running. If the compressor is not running that might be why your refrigerator is not cooling. Still, I would contact a local authorized technician, for a full diagnosis. This way it can be determined what exactly is the cause of the NO COOL issue.
-Best Regards-
WP
Apr 04, 2014 | Frigidaire Refrigerators
My frigidaire model # FRS6LF7J type 7 runs but it don't get cold in both side. after reviweing it, i found that the fan inside the frizer is not working, its new frigidaire and had it home for 9 weeks.
Well, that fan must run to cool properly but that might not be the only problem, The fan is probably controlled by the control board in yours since it's a new one. The fan behind it and in the freezer should run when the compressor is running.
Sep 08, 2010 | Frigidaire Refrigerators
My refrigerator doesn't get cold, and has a sound likr click frigidaire model#glrt83tes
First you can check the compressor behind the refrigerator, make sure the compressor is alive/ running or not. if it does not mean your compressor is damage or worn out, but if running there is leakage between the cooling duct so that its run out of freon. then it will not cool your refrigerator.
Jul 23, 2010 | Frigidaire GLRT83TES Top Freezer...
Frigidaire AS-17 does not cool, freezer works fine
Hi, Check the freezer and see if the fan motor is running. Remove the rear panel and check for a frost or ice build up inside the rear freezer panel. Please let me know what you find so I can assist you further.
Vic
Jun 28, 2009 | Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
