I have a tecnolec washing machine dislaying ERR1 stopped working after a power cut
4 Suggested Answers
  • 22 Answers
SOURCE: error code and machine not washing
Some washer and dryers will clear the codes by unplugging the machine from the wall.... Leave it unplugged for 30 secs... then plug it back in..... may clear code..... and may unlock door so you can get the clothes out.
Unsure of the code meaning.... but if you clear it by power down and it works don't worry about it unless it returns quickly.....
Posted on Jul 13, 2010
  • 1416 Answers
SOURCE: I have a Teka TKE
This code refers two 1 of 2 things first is the electronic touch pad that has shorted out OR some time an indication of over flow of water in to the panel indicated by the sense sensor and needs to be replaced so have this checked first next is the electronic control circuit or ecc for short or need a little service .
some models the touch pad is part or panel of the ecc okay.
You should remove the touch pad or the ecc and have them tested at any appliance parts center if you have one in your home town or get a better one from the store around your local area
If your oven still has the warranty this will be covered under this okay
Hope this is very helpful for you?
Thank you and thanks for using fixya.
Posted on Oct 15, 2010
caroldon
  • 17130 Answers
SOURCE: machine stopped working
This can be due to the fact that the program controller unit has failed within and has a short that caused the cut off in the circuit.
Remove the panel and check for short. check if any rectifier or capacitor within has shorted, normally since this panel board is epoxy filled the possibility of repair is less and must be replaced.
Also disconnect lines from the board to confirm if the motor or pump circuit is not shorted.
Posted on Jul 06, 2012
I have lg front loading washing machine and it dislays DE , i know its means door error, but the door is closed , still the same eror. Can some one suggest.
Closed but does it lock closed so the washer can run . try leaning against the door .if it works call a repairman and get it replaced
Oct 24, 2015 | LG Washing Machines
Error 1 in teka washing machine 1260 WD. What does it mean?
code E1 Main electronic control board failure Unplug the washer. Check the wiring connections on the main electronic control board in the console. If the wiring connections are sound, replace the the main electronic control.
Nov 07, 2014 | Washing Machines
Error message ERR1 on BWD1212 washer dryer?
Door not closing properly. Hinges may need adjusting. The door switches are very sensitive
May 06, 2014 | Haier washer BWD1212 User Manual
Haier washing machine HMV1070KFL motor
The only individuals who understand the codes are the manufactures service center. I suggest you go on line or call the factory for these codes and/or get the repair manuals.
Mar 25, 2014 | Haier Washing Machines
PROLINE LOGIC 6 KG AA WASHING MACHINE- It is stuck on "error2" what does this mean and how can I rectify it. Thanks
Hi I also have a problem with the washing machine. It shows Err1 and it can't work. Anyone could help me?
Jan 15, 2011 | Washing Machines
Error code and machine not washing
Jul 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing machine don't cut off while taking water.sensor not working.what is price of sensor?
If the water will not stop unless the tap is shut off, the inlet valve is faulty...This is the most common fault.. If the sensor is faulty, or the small hose has detached itself, the inlet valve is not receiving instructions to turn off and will only stop when power is off..Good luck..Nomess
May 20, 2010 | Washing Machines
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops...
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
Washing Machines Logo
228 people viewed this question
Top Washing Machines Experts
