Question about Radio Flyer Steer and Stroll Deluxe Trike
Need a new steering cable - Radio Flyer Steer and Stroll Deluxe Trike
How do I remove steering cable from 40 hp Mercury outboard
Depending on your boat , you normally have to unbolt the engine then remove off the transom , with help or a crane etc ! First remove the steering link bar then undo the large nut on the steering cable then disconnect the battery and all other cables and control cables etc then unbolt the engine and lift up so you can remove the steering cable ! If any corrosion in the tube you must clesn out and grease before fitting new cable and all others in reverse order !!
Feb 24, 2015 | Boating
How to fix the linkage on the transmission on 2001 Lincoln navigator
First thing is to get safety glasses,block wheels securely !!...set emergency brake..,get a good flashlight.Disconnect negative battery cable...Some can wear inside the steering column,some can be a worn linkage cable ...The lever on the transmission located under vehicle Trans at lower part of trans,driver side can become loose or possibly damaged...First get under vehicle with safety glasses and observe operation of the lever where shift cable is mounted while assistant puts it in park...make sure the trans shift lever mounting nut is tight before shifting..If assistant can't get it in park use your hand and push forward on the linkage arm and it should go into park manually...If this is the problem you need to change shift cable...Some wear inside the column where steering wheel is mounted..If cab shifter feels very loose ..You will have to remove steering wheel and column cover to inspect."..The cable runs from trans to the steering column..Look between gas and brake pedal and verify cable coming up through floor board and runs to steering column...Double check shifter lever at trans is tight because it is mounted on a splined stud and it can strip the stud threads if it becomes loose..If loose remove lever and inspect splines for damage..Call dealer and make sure they have the part..Remove old cable from trans and put it in park with your hand...Remove and replace cable..Be sure lever inside cab and lever on the trans are both fully engaged into park while cable is removed before installing new cable....Attach new cable.....
Oct 16, 2014 | 2001 Lincoln Navigator
Steering on my boat motor is stiff evinrude
First disconnect the motor and see if that stiffness is from the pivot of the outboard or from the steering cable.
If motor, try the grease gun with marine grease (auto grease will coagulate in salt water) and put some heat to it (oxy is the ticket, but not to hot- just smokin) and swing in back ad forth. Keep it moving as ir cools off as you may need a few treatments.
If its the cable-- buy a new one. If you;d rather buy beer, take the end off the motor and hose clamp the cut end of a bicycle inner tube to the plastic of the housing. Then fill with 5w20 motor oil and hang it all higher than the steering wheel till morning. Come out about every 3rd beer and spin the steering lock to lock. Put a bucket under it in the morning to catch the extra and hook it back up.
Sep 04, 2012 | Light Boating
Boat steering cable
This steering is swedged at the factory and can not be separated. If you will remove one end. (Motor end works best) And slide a cut bicycle innertube down over the end and hose clamp it to the plastic covering, you can force some light oil into the steering.
If this doesn't work in a day or two, you need a new steering cable.
Jul 18, 2012 | Light Boating
Steering cable is broken and needs to be replace. having a problem removing the cable. a detailed schematic would be helpful.
there is no such thing the cable unbolts from the steering head and the motor then ust pull the entire thing out . best to pull a rope thru with it tho to help get the new one in
Oct 08, 2010 | Bass Pro Boating
Now to install igintion switch
Removal & Installation The ignition switch or warning switch can be replaced without removing the steering lock assembly. The ignition switch is on the back of the assembly and the warning switch on the side.
  1. Disconnect the negative battery cable and insulate the terminal end.
CAUTION The air bag system must be disarmed before removing the steering wheel. Failure to do so may cause accidental deployment, property damage or personal injury.
  1. Remove the steering wheel and the steering column upper and lower covers.
  2. Remove the spiral cable assembly.
View of the steering lock and ignition switch assembly
  1. Remove the combination switch from the steering column.
  2. Remove steering column support nuts and lower the steering column.
  3. Disconnect the ignition switch wiring and interlock cable (if equipped).
  4. Remove the bolts that secure the steering lock and remove steering lock assembly.
To install:
  1. Install the steering lock assembly and secure with new shear type bolts.
  2. Connect the ignition switch wiring harness and the interlock cable.
  3. Raise the steering column and secure with mounting nuts.
  4. Install the spiral cable assembly.
  5. Install the combination switch, steering column covers, and the steering wheel.
  6. Connect the negative battery cable and enable the air bag system.
May 23, 2010 | 1997 Nissan Maxima
How do I fix the power steering n my mazda rx8 04?
My RX8 had the same problem. First, change your battery cable ends. On the Positive cable there is a white wire that powers the power steering. It probably has a bad connection at the battery post. I cut the end off my rx8 and just put a regular battery cable end on it and my problem was solved.
Jan 06, 2010 | 2004 Mazda RX-8
How do you remove or drop down the tilt steering column on a 1989 F250 4x4 7.3 diesel? I'm trying to replace the clutch and brake peddle support pivot bracket that is broken. I've gotten the bracket...
this is for 1996, don't have 89.
these may be steps you need
  1. Remove pinch bolt from steering shaft flex coupling.
  1. Disconnect shift cable from selector lever pivot.
  1. Remove shift cable from steering column lower mounting bracket by pushing tab on cable in and sliding cable off bracket.
  1. Disconnect ignition switch (11572) by loosening bolt and removing connector. The bolt is part of connector and can not be removed.
  1. While supporting steering column, remove four retaining nuts.
  1. Disconnect collapsible intermediate shaft from U-joint at lower end of steering column.
  1. Remove steering column from vehicle.
Oct 29, 2009 | 1989 Ford F 250
Carmy horm will not work year 1996
You have a damaged Spiral Cable, or, as more commonly referred as a "Clockspring". This is the wiring that connects the steering column to the steering wheel. Inside the housing for the Clockspring is a flat wire harness that connects the vehicle harness to the variuous controls on the steering wheel...the horn, the air bag, the cruise switch, etc etc. What you need to do is go to a Toyota dealership parts department, and purchase a Spiral Cable assembly. Pull the steering wheel, and you will see it. Remove the 4 screws, and pull the Cable unit, and unplug it. Fit the new Cable assembly, and refit the screws; plug it all back together. Just remember to keep the steering wheel CENTERED...the replacement Cable assembly comes in teh "Centered" position. Do not rotate it left or right, or you will lose the centering of the cable..This will break the wire..
Feb 05, 2009 | 1996 Toyota Camry
Frozen steering on mariner 75
It sounds like your steering cable is rusted in the eng steering bracket or your cable has gone south (Rust) try some heat to free it up and if that dont work its time for a new cable
Oct 04, 2008 | Simrad 20187423 Teleflex Adapt Lf 3000...
Radio Flyer Steer and Stroll Deluxe Trike Logo
19 people viewed this question
Top Radio Flyer Toys Experts
Tom Chichester
erex 01
erex 01
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
